SG112-24
adarvela
I am trying to link two cisco SG112-24-NA switches via a 10GB copper SFP. Is there anything I need to do to configure them
marce1000
 - Check this thread :
        https://community.cisco.com/t5/small-business-switches/sg100-24/td-p/2562479
 M.
Martin Aleksandrov
Hi adarvla,
The Sx110 series are unmanaged, therefore, nothing to configure - just plug in the transceivers and connect the switches.
Martin
Can you recommend a Copper SFP brand and model that will work. I need 10Gb
Copper SFP's that will work.
Hi there,
The SG112 does support 1G SFP uplinks only. Below you can find supported SFPs.
Martin
