03-06-2013 06:23 AM
I have upgraded my SG200-08 switches from firmware version 1.0.5.1 to version 1.0.6.2. Since that new firmware is active, the network-printing from my Macbooks and iMacs is not working anymore. They all have TCP/IP connected network printers (not based on Bonjour connections) and they cannot print anymore; timeout communicating to printer. Windows workstations on the same network are still able to print to the network printers, only the Mac's do have this problem.
I am still able to view printer-information via the Mac's, so communicating is still possible. Also surfing to the admin-page of these printers is still working, only sending the actual print-job is failing.
I have reset the SG200-08 switches to factory defaults, but still no printing.
Finallly I did a downgrade, back to firmware version 1.0.5.1 and now printing from the Mac's is working again.
Any ideas, perhaps a firmware bug?
I have seen the new firmware version 1.2.9.44, but there are only language files available for the SG200-08, no firmware file...
So I don't know if this new version perhaps solves this problem.
Kind regards,
Rene.
02-18-2014 08:47 AM
Christian,
There is not and will not be a Version 1.3.7.18 for the 8-port switch. Due to hardware limitations the 8-port switch is not capable of sharing firmware with the larger switches.
Version 1.0.7.4 is the latest version for your switch. If a new version is released for the 8-port switch it will likely follow the 1.0.x.x format, not 1.3.x.x.
- Marty
01-26-2017 06:59 AM
Are you kidding me? I have installed the latest FW 1.0.8.3
And the problem is still there. I bought two SG 200-08 in 2016. And I can't print when using a Mac.
I am soooo disappointed of cisco. That was the last switch I ever bought from cisco.
Over and out!!
