SG200-08P 8-Port Gigabit POE Smart Switch - Missing SNMP
itwick2014
just bought and installed an SG200-08P 8-Port Gigabit POE Smart Switch with firmware upgrade to Release 1.0.8.3.
Where can I find the SNMP funtion? It is not visible in the webinterface unlie for the 200-50 switch series.
The product catalog lists SNMP for all 200 Cisco switches.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-100-series-unmanaged-switches/data_sheet_c78-667827.html
IC
ktonev
My name is Kristian and I am one of the engineers from the Small Business team.
Unfortunately, the SG200-08 model does not support SNMP functionality. Apologies for any inconvenience caused.
You can also refer to the link below to another thread in our support forums regarding this issue -
https://supportforums.cisco.com/discussion/12046456/sg200-08-no-snmp-agent
Kris
That's a great response, ALL Cisco Small Business products are non-returnable at Canada Computers.  It will still do the job it was purchased for, but it would have been helpful to have accurate information BEFORE I bought a non-returnable product.
