sg200-08p on 11-14V DC?
lyrnxg
Hello, does anyone use or know if a sg200-08p can run fine between 11-14V DC?  I am looking to power it from a battery.  Thank you
balaji.bandi
it required 12V DC as per the document, it should be ok as long as it can not go beyond 12V
BB
Have you or anyone else tried feeding more voltage? A lot of modern technology can handle over voltage.
Not that i have tried, Cisco do not recomend to use any 3rd party input adpator to use other than recommended one, since you willing to test - so that is the advise was suggested.
BB
