SG200-08p PoE ports 3&4 not working
joekwon80
I have been testing all possible issues with this sg200-08p
I have 3 PoE cameras that are connected to the switch. Only ports 1&2 are up and are sending power to the cameras. I tested to see if the camera was the problem but when I plugged camera 3 into either port 1 or 2 it started up just fine. I've turned off green ethernet on all the ports as well.
The summary page shows:
Maximum Available Power:
0W
Threshold Power: 0W
Consumed Power: 0W
even though 2 cameras are currently running.
the log file reads this:
193 1970-01-01 00:37:43 Error POE[poe_monitor] hpc_poe_brcm.c(568) 17751 %% Failed to Read -- -2
194 1970-01-01 00:37:43 Error POE[poe_monitor] hpc_poe_brcm.c(708) 17752 %% Receive RecvErr Failure.
195 1970-01-01 00:37:43 Error POE[poe_monitor] hpc_poe_brcm.c(568) 17753 %% Failed to Read -- -2
196 1970-01-01 00:37:43 Error POE[poe_monitor] hpc_poe_brcm.c(708) 17754 %% Receive RecvErr Failure.
197 1970-01-01 00:37:44 Error POE[poe_monitor] hpc_poe_brcm.c(568) 17755 %% Failed to Read -- -2
198 1970-01-01 00:37:44 Error POE[poe_monitor] hpc_poe_brcm.c(708) 17756 %% Receive RecvErr Failure.
199 1970-01-01 00:37:44 Error POE[poe_monitor] hpc_poe_brcm.c(568) 17757 %% Failed to Read -- -2
200 1970-01-01 00:37:44 Error POE[poe_monitor] hpc_poe_brcm.c(708) 17758 %% Receive RecvErr Failure.
1 1970-01-01 00:37:19 Error POE[poe_monitor] hpc_poe_brcm.c(568) 17572 %% Failed to Read -- -2
2 1970-01-01 00:37:44 Error POE[poe_monitor] hpc_poe_brcm.c(708) 17760 %% Receive RecvErr Failure.
One last note. The port lights are green instead of amber on ports 1&2.
Any help would be greatly appreciated.
--joe
Philip D'Ath
Have you tried a firmware upgrade on the switch?  I note this model has 32W of PoE.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-200-series-smart-switches/data_sheet_c78-634369.html
So you could power 4 ports of 7.4W, or if the cameras use 11W or more then only two ports (as a third port would need 33W - more than the PoE budget).
How much power do your cameras use?
Tried the firmware upgrade and defaulting the switch. The cameras use 5w each.
Hi, I appreciate this is old information but it would be great if there was an outcome, many thanks :).
