Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2925 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4508 Views
  • 1 replies
  • 16 Helpful votes
I am trying to setup a layer 3 switch at my daughter's real estate business.  I cannot seem to setup a static route on my SG500X-24 switch.  I am getting an error message "Only a directly connected router can be defined as the gateway"  which is what...
Excuse the newbie in me, VLANS are new to me and I've decided to practice and learn a little bit more about them. I have a PFSense router box that I made, I have 3 VLANS assigned to one of the interfaces, each with their own DHCP server. VLAN 10 - 19...
What is the link for selecting cisco online simulator for different products / switches? I have found couple of links for SG-300 and SG-200 series switches. I want to try online simulator for SG-500 and Catalys 2960 series. Are they available, if so ...
jacobslive by Level 1
  • 34704 Views
  • 5 replies
Hello,I have one Cisco SG-300 10 PP switch. Earlier this was working fine but suddenly it stopped working. I took this device on the console to see what is happening and I got error messages as follows. I have tried with firmware upgrade but nothing ...
Hola, para solicitar su ayuda en la creación de los puertos truncados en un SG500-52P, el problema que se presenta en la creación de un puerto troncal que se puede ver todo el vlan creado y lograr una interacción con ellos, espero y encuentre Ayuda c...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
