11-15-2016 11:48 AM
Good day I have is SG200-26 26-Port Gigabit Smart Switch with version 1.3.7.18, how to update the firmware to the latest version. 1.4.5.02
1 differs from the Smart Switch Firmware Smart Switch MIB
2 What is the sequence of the firmware.
I'm sorry I used the translator. thanks
Solved! Go to Solution.
11-21-2016 01:19 AM
hi
for switch software upgrade you can always check corresponding firmware release notes in order to find out this kind of information. in your case you can upgrade directly to latest version as there is no specific prerequisite.
in release notes you can see changes between firmware versions and see if some of them could be related to SNMP MIB or not. But anyway you can check if new MIB is available for download in corresponding download section for your device.
11-21-2016 01:19 AM
hi
12-20-2016 11:18 PM
Good afternoon thank you for your help, for your reply.
