SG200-26 DHCP Management vlan
blankert.robert
I successfully replaced my DGS-1100-24 switch with a 26 port Cisco SG200.
There is however one issue with the remaining; attached dlink switches that were configured to use a management vlan do no longer obtain a dhcp address. This was working fine before swapping the switch.
The SG200 is working fine it self using management vlan 10 it obtains an IP address. All other defined vlans work fine for connected devices, they all get dhcp addresses. Only where a switch is attached all vlans are parsed ok only the management vlan on the switch does not get an IP.
Tried several approaches, given the fact that it worked fine it should be something with the SG200, tried the following so far without success;
- vlan1 left as default vlan, nothing run over this vlan
- vlan 10 was assigned to the port as tagged and untagged in either case no IP on the attached switch assigned.
The attached switch does however receives all the vlans as an attached unifi access point obtains an vlan 10 ip over dhcp just fine being connected to the switch. Also all the other vlans are working fine on the access point.
Also switching the management vlan of on DGS switch and setting to vlan 10 untagged and pvid to 10 still no dhcp address assigned.
The only thing that works is assigning it a static address than the management interface is reachable. Just like dhcp gets blocked for the switch management interface but not any other connected devices.
Sg200 ->          DGS1100-5 ->      Unifi access point
vlan10/dhcp     vlan10/no dhcp    vlan10/dhcp
What could be the difference between a DGS1100-24 and SG200-26 that this does not work any longer.
Any suggestions explaining this behavior would be welcome.
erisysadmin
I think that I have the same problem.  I have VLAN 1000 set as my public Wireless on ports 1 and 2.  VLAN 2000 is my business network and set as the default VLAN.  Anything on my default VLAN will get an IP address and seems to work fine.  My AP on VLAN 1000 will not get an IP address.  Looking in the arp table on the SG200, I see all the arp entries on the SG200 for the devices on VLAN 1000, even if they are on different switches.  HP switch that is the uplink for the SG200, I do not see the mac address of the SG200 or AP, but running show CDP neighbor, my HP switch does see the SG200 on the port for VLAN 1000.
