SG200-26 ,Why two-port link aggregation speed is 1000Mb / sec
zhangxu liu
Hello,Everyone;
    My switch is SG200-26.
    I've set up on my server link aggregation, aggregation is LACP NIC, my server model is "HP Proliant MicroServer Gen8", the server has two Ethernet G-ports, the installation of Windows Server 2012 R2,
    In SG200-26, I created LAG1 and add to its plus two ports.
    and now my computer and the server can ping each other, and can copy files to each other .
    The problem now is that the speed of 2Gb / s of my server, network card display, but in SG200-26, LAG1 display speed 1000Mb/sec of
    I am Chinese, English is not good, please forgive me.
Thank youHello,Everyone;
Brendan Kearney
with 802.3ad with LACP you do not get a 2 Gb link with the bonding.  You get 1 Gb for TX (transmit/upload) and 1 Gb for RX (receive/download).  This is what the standard provides.
As far as i know, the SG500 series of switches support balance-xor bonding methods, which may give you the 2 Gb bond you are looking for.
If so, what significance there NIC teaming? With a single NIC duplex mode so what's the difference?
Other people have been tested with the SG200-8, if the two workstations both tasks simultaneously copied to the server, the total flow rate is more than 1000Mbps, the total flow of around 1800Mbps.
I was a beginner, a China Luoyang, ask your advice, thank you.
For 802.3ab my understanding is that after the port aggregation, the flow rate can not exceed a single task 1000Mb / s
