SG200-50P & SNMP temperature monitoring
damian.woz
Is it possible to monitor SG200-50P temperature and FAN status (or each FAN RPM) via SNMP? If yes, which OID's are responsible for monitoring this?
Hi Damian,
Those are for fan status. Have not seen the temperature yet but will try to verify and get back to you.
Fans Unit 1
.1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109249
Fans Unit 2
.1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109250
Fans Unit 3
.1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109251
Fans Unit 4
.1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109252
Aleksandra
6 Replies 6
damian.woz
Bump. Anyone knows?
Hi Damian,
Fans Unit 1
Fans Unit 2
Fans Unit 3
Fans Unit 4
Aleksandra
Thanks for answer. About temperature monitoring - I found something like: rl env fan data temp - The unit temperature - 1.3.6.1.4.1.9.6.1.101.83.5.1.1.2.1
Now I'm also searching for OIDs that can show me: total bytes RX / TX and RX errors on LAG interfaces.
So I also found RX Packets with Errors on LAG interfaces (which is iso.3.6.1.2.1.2.2.1.14.1000 - iso.3.6.1.2.1.2.2.1.14.1003).
I'm not 100% sure about this 2 OID's below:
RX Total Bytes on LAG if: iso.3.6.1.2.1.2.2.1.10.1000 to 1003
TX Total Bytes on LAG if: iso.3.6.1.2.1.2.2.1.16.1000 to 1003
Can anyone confirm whether this OIDs are properly?
Bump...
Can someone confirm if this RX/TX Total Bytes on LAG are properly (or not)?
Hi Damian,
I have not done LAB for this yet. But I would suggest you to call Cisco Small Business Support Team and they would be able to assist you:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
