SG200-50P VLAN to Uplink Setup Question
aforrest111
Hi, I'm attempting to setup vlans on an SG200-50P (layer 2) switch which is connected to a Meraki MX80. The vlans are working off the MX80 but they are not connecting to the vlans on the SG200-50P. I'm starting to think it may be a configuration change needed to the SG200-50P uplink interface to allow the new vlan tagged packets to leave off that port? Can someone help clarify the settings needed on this switch to create and pass vlans to an uplink?
Thank you!
aforrest111
Disregard, I've solved the issue. Needed to use the "Port VLAN Membership" to "Join VLAN" on the switch interface which is connected to the router. So interface now is 1UP, 10T.
Yes, the Ports on the SG300's are 'Trunks' by default but they only accept untagged frames in the default vlan (i.e. vlan 1).
In order to have them accept tagged frames, you need to configure this as you did.
Thanks for the clarification on this.
