SG500 POE issue on one port, worked fine for over a year!
jgould0011
I have 2 SG500 52 port switches in a stack. One is non-POE and the other is POE. I use the POE switches primarily to drive our Yealink T22P and T46G phones. They have worked flawlessly for about a year.
This weekend I updated the firmware and boot for the switches to the latest release.
SG500#sh ver
       Unit             SW version         Boot version         HW version
         1               1.4.0.88            1.4.0.02               V02
         2               1.4.0.88            1.4.0.02               V02
Now all of a sudden a port that is being used to power one of the phones isn't working correctly, and the behavior is VERY odd (I will explain in a second). I have 20+ phones on this same POE switch that have no issues. I'm WELL under power budget since each phone draws about 2.5W.
Any phone that is plugged into this bad port at first looks like it works fine. It is in the right VLAN, auto smartport correctly identifies it, LLDAP-MED works as it should. The phone looks to be operational. It even might work fine for a while. But eventually when making a call the light in the screen starts flickering like crazy and you get a "static" sound on both ends of a call. It sounds like electrical interference. I can make a call and it will be fine for 1 minute and the next it starts doing this. It is NOT the phone. The same phone in a different switch port does not do this (in fact 20 others phones on different ports don't do it). ANY phone in this port shows this behavior.
The port in question (port 36), is showing Local POE as 0 Watts, Remote POE 2.9W (in Administration -> Discovery-LLDP -> LLDP Port Status). All other phones show Local POE as something like 2.5W. All settings on this port (36) are exactly the same as the rest of the ports on the switch that work fine with the EXACT same phones. I know it is the port on the switch that is causing the issue as well because I was able to isolate it. I tested the phone by plugging the phone that appears to be bad into a different wall outlet. I tested the wall outlet by switching the cables from the patch panel to the switch ports. I changed the patch cables as well. It is the switch port for a fact.
I did some searching and found some similar info related to the SG300. So I ran some of those commands and found some more info.
SG500#show power inline gi2/1/36
  Port      Powered Device         State          Status    Priority   Class
gi2/1/36                            Auto        Searching     low     class4
Time range:
Power limit: 30.0  W
Inrush Test: Enable
Legacy Mode: Enable
Port Status:               Port is off - detection is in process
Overload Counter:          0
Short Counter:             0
Denied Counter:            2
Absent Counter:            0
Invalid Signature Counter: 1
Notice the port status (it shows this all the time) and the Class.
This is compared to the same phone in a different port showing this;
SG500#show power inline gi2/1/22
gi2/1/22                            Auto            On        low     class2
Time range:
Power limit: 30.0  W
Inrush Test: Enable
Legacy Mode: Enable
Port Status:               Port is on - valid capacitor/resistor detected
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            5
Invalid Signature Counter: 0
I am afraid to make any changes across all ports on the switch since they are working fine. So I am trying to make changes on just port 36 of this switch. I tried turning off EEE settings, didn't help. Tried turning off the VLAN and auto smartport settings, didn't help.
Is the port busted (if so I'm pretty upset with the purchase of this switch)? Is it something caused by the latest firmware?
In 15 years I haven't had a single faulty piece of hardware. If this is I sure hope Cisco is easy to deal with.
7 Replies 7
jgould0011
More info to help diagnose:
Port based power-limit mode
Inrush Test: Enable
Legacy Mode: Enable
Unit  Power  Nominal Power   Consumed Power   Usage Threshold   Traps   Temp (C)
 2     On      375 Watts     68 Watts (18%)         95         Disable     39
gi2/1/1                             Auto        Searching     low     class4
gi2/1/2                             Auto            On        low     class2
gi2/1/3                             Auto            On        low     class2
gi2/1/4                             Auto            On        low     class2
gi2/1/5                             Auto            On        low     class2
gi2/1/6                             Auto            On        low     class2
gi2/1/7                             Auto            On        low     class3
gi2/1/8                             Auto        Searching     low     class4
gi2/1/9                             Auto            On        low     class2
gi2/1/10                            Auto            On        low     class2
gi2/1/11                            Auto            On        low     class0
gi2/1/12                            Auto        Searching     low     class4
gi2/1/13                            Auto        Searching     low     class4
gi2/1/14                            Auto        Searching     low     class4
gi2/1/15                            Auto        Searching     low     class4
gi2/1/16                            Auto            On        low     class2
gi2/1/17                            Auto        Searching     low     class4
gi2/1/18                            Auto            On        low     class2
gi2/1/19                            Auto            On        low     class2
gi2/1/20                            Auto            On        low     class2
gi2/1/21                            Auto            On        low     class0
gi2/1/23                            Auto            On        low     class2
gi2/1/24                            Auto        Searching     low     class4
gi2/1/25                            Auto            On        low     class0
gi2/1/26                            Auto            On        low     class2
gi2/1/27                            Auto        Searching     low     class4
gi2/1/28                            Auto        Searching     low     class4
gi2/1/29                            Auto        Searching     low     class4
gi2/1/30                            Auto        Searching     low     class4
gi2/1/31                            Auto            On        low     class2
gi2/1/32                            Auto            On        low     class2
gi2/1/33                            Auto            On        low     class2
gi2/1/34                            Auto            On        low     class2
gi2/1/35                            Auto            On        low     class2
gi2/1/37                            Auto            On        low     class2
gi2/1/38                            Auto        Searching     low     class4
gi2/1/39                            Auto        Searching     low     class4
gi2/1/40                            Auto        Searching     low     class4
gi2/1/41                            Auto        Searching     low     class4
gi2/1/42                            Auto        Searching     low     class4
gi2/1/43                            Auto        Searching     low     class4
gi2/1/44                            Auto        Searching     low     class4
gi2/1/45                            Auto            On        low     class0
gi2/1/46                            Auto            On        low     class0
gi2/1/47                            Auto        Searching     low     class4
gi2/1/48                            Auto        Searching     low     class4
I have the same issue with my sg500x but with a wifi hotspot device. I had hoped there was a magic reset the port command but sadly not! Ive isolated my issue down to the port, device powers up in adjacent ports, replaced cables, etc but port refuses to acknowledge theres anything connected. Non PoE devices work fine however.
Heres my bad port...
switch91d02b#show power inline gi1/14
gi1/14 Auto Searching low class4
Time range:
Power limit: 30.0 W
Inrush Test: Enable
Legacy Mode: Enable
Overload Counter: 0
Short Counter: 0
Denied Counter: 0
Absent Counter: 0
and heres the same device in a working neighbour port
switch91d02b#show power inline gi1/13
gi1/13 Auto On low class0
Time range:
Power limit: 30.0 W
Inrush Test: Enable
Legacy Mode: Enable
Overload Counter: 0
Short Counter: 0
Denied Counter: 0
Absent Counter: 0
Don't waste your time. Call Cisco support, the switch port is busted. You will need a replacement.
thank you. call logged with Cisco.
Charles Hill
According to your posting, you are testing it at the jack and not at the switchport?  If this is accurate, I would plug the phone directly to the switchport, just to confirm.
I know you have tested it at different jacks, but I have seen stranger things...I never say never...
"I was able to isolate it. I tested the phone by plugging the phone that appears to be bad into a different wall outlet. I tested the wall outlet by switching the cables from the patch panel to the switch ports. I changed the patch cables as well. It is the switch port for a fact."
Yes, that is what I did initially. I have since tested it at the switch itself. Same behavior. Also, strangely, the switch port light on the right of port 36 doesn't come up amber. Plugged into any other port and it does.
I just got done with Cisco support. They did a WebEx and looked through it, I showed them what I found, and they have concluded that the port is "messed up". :)
I still have next business day support on the SG500 it appears. So I'm RMA'ing the old switch and they are overnighting me a new one.
Very good!  Thank you for the update.
