SG220 Weak SSH Algorithms enabled
Dirk van Dam
We have a bunch of cisco sg220 switches. We did a pentest and the outcome is that we have weak algorithms enabled.
is there a way we can disable these weak algorithms. I look everywhere, but no answers found. We use the latest firmwares in these switches.
Hope someone can help me out!
marce1000
 - You don't have such options and or possibilities available on small business switches, if business requirements are strict you need to look at higher level boxes and or IOS based.
 M.
marce1000
 M.
Dirk van Dam
Thanks for your reply. I will inform my customer they have to upgrade
