Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2873 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4429 Views
  • 1 replies
  • 16 Helpful votes
Hi allMy first time posting on here so I'm hope you all have patience with me thanks in advance.What I have done through the web GUI is set up two vlans, vlan2 and vlan3 with different ip's with dchp pool. They work fine, and there is no communicatio...
harrisp32 by Level 1
  • 1017 Views
  • 8 replies
Hi,I have a brand new SG250-08HP that was working fine for the last week and then ive gone to power it on and now its stuck in a boot loop where the startup config will load and then 10 seconds later all the ports shutdown and then the unit reboots a...
Resolved! Multicast
Please help ,multicast or IPtv will work for below setup ?  i have huawei access switch model s5735 connected to cisco core switch 3850 series via huawei sfps.  Cisco core 3850Vlan 65 IPTVip multicast auto-enableInterface Vlan 65ip address 192.168.65...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
