sg300-10 fatal errors. Faulty hardware?
natxo asenjo
Quite randomly I have my sg300-10 crash and I see this in show logging file:
#show logging file
Logging is enabled.
Origin id: disabled
Console Logging: Level info. Console Messages: 0 Dropped.
Buffer Logging: Level info. Buffer Messages: 103 Logged, 103 Displayed, 1000 Max.
File Logging: Level error. File Messages: 143 Logged, 105 Dropped.
3 messages were not logged
Application filtering control
Application                 Event                       Status
AAA                         Login                       Enabled
File system                 Copy                        Enabled
File system                 Delete-Rename               Enabled
Management ACL              Deny                        Enabled
Aggregation: Enabled
Aggregation aging time: 300 Sec
28-Dec-2016 22:54:53 :%AAA-F-USERNFD: AAAP_inner_authenticate_user: user entry not found
***** FATAL ERROR *****
Reporting Task: SSHU.
Software Version: 1.4.7.5 (date  15-Nov-2016 time  11:19:18)
0x16aee8
0x16b44c
0x16700c
0x7736f0
0x4f23dc
0x4f2cd4
0x4f2ef0
0x616828
0x378fe8
0x375968
0x375a6c
0x1223f0
***** END OF FATAL ERROR *****
28-Dec-2016 21:38:40 :%AAA-F-USERNFD: AAAP_inner_authenticate_user: user entry not found
Software Version: 1.4.5.02 (date  20-Apr-2016 time  12:22:49)
0x16aee8
0x16b44c
0x16700c
0x7728b8
0x4f23b4
0x4f2cac
0x4f2ec8
0x615e08
0x378fc0
0x375940
0x375a44
0x1223f0
28-Dec-2016 21:15:51 :%AAA-F-USERNFD: AAAP_inner_authenticate_user: user entry not found
0x16aee8
0x16b44c
0x16700c
0x7728b8
0x4f23b4
0x4f2cac
0x4f2ec8
0x615e08
0x378fc0
0x375940
0x375a44
0x1223f0
28-Dec-2016 20:20:32 :%AAA-F-USERNFD: AAAP_inner_authenticate_user: user entry not found
0x16aee8
0x16b44c
0x16700c
0x7728b8
0x4f23b4
0x4f2cac
0x4f2ec8
0x615e08
0x378fc0
0x375940
0x375a44
0x1223f0
coreswitch#show version
SW version 1.4.7.5 ( date 15-Nov-2016 time 11:19:18 )
Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 )
HW version V02
coreswitch#show system
System Description: SG300-10 10-Port Gigabit Managed Switch
System Up Time (days,hour:min:sec): 00,23:45:03
System Contact:
System Name: coreswitch
System Location:
System MAC Address: 64:d8:14:5e:d9:48
System Object ID: 1.3.6.1.4.1.9.6.1.83.10.1
Fans Status: N/A
The switch still works ok after resetting itself, but this should not be happening, should it?
TIA for any tips/clues as to what is going on.
jonrodr2
My name is Jonathan and I am one of the Engineers here at Cisco Small Business.
I apologize for the delay in answering and for any inconvenience with the unit, please let me know the following.
-since the unit went down, have you had the same issue?
- I see that the logs show the fatal error with the 2 newest versions, so for how long has this issue been happening?
-have you tried to do a factory reset and then reupload the config file?
Thanks.
hi Jonathan,
Thanks for getting back to me, I already expected delays with the holiday season, no need to apologize.
Since that day I have had just one more crash. It tends to happen (or I tend to notice it) after changing a setting.
Tomorrow I will try resetting the unit to factory defaults and re-loading the configuration; good tip, I should have thought of that myself ;-)
Thanks again.
I have reset the system to default settings using the web ui (reboot, restore to factory defaults), restored the config file, rebooted again, checked that everything was ok.
After that I proceeded to modify a setting, in this case I added public key authentication to ssh. Short after that, the system proceeded to reset itself (cold startup in the log).
#show logging file
Logging is enabled.
Origin id: disabled
Buffer Logging: Level info. Buffer Messages: 36 Logged, 36 Displayed, 1000 Max.
File Logging: Level error. File Messages: 178 Logged, 38 Dropped.
AAA Login Enabled
04-Jan-2017 16:14:26 :%AAA-F-USERNFD: AAAP_inner_authenticate_user: user entry not found
0x16aee8
0x16b44c
0x16700c
0x7736f0
0x4f23dc
0x4f2cd4
0x4f2ef0
0x616828
0x378fe8
0x375968
0x375a6c
0x1223f0
any clues?
