SG300-10 Initial Setup Question
patrick.hurley
Level 3
Level 3
I changed my login id and password from the default of cisco/cisco but it only asked me to change the password, not the username and I cannot get back in because cisco as the username does not work and neither does root or admin.  What is the username set to after changing the password for the first time?
balaji.bandi
if not changed the username it should be cisco and a new password.
reload the device and test it.
if you like to reset to factory again :
With the power on, press-and-hold the Reset button for more than 10 seconds.
BB
Thanks!
