SG300-10 IP-Helper
nhj000001
Hello everyone,
I'm trying to configure ip-helper on my SG300-10 but can't figure out how to do it. I've been using these steps to configure mine but i run into a stop at "Device(config-if)# ip helper-address 172.16.1.2" Here i don't have the command ip helper-address.
Is it that my device can't use ip helper? Or did i miss some other configuration in order to be able to configure iphelper?
Thanks in advance :-)
Mark Malone
I was looking for the same guide, thank you for your help !
This is just what i needed, thanks alot!
