SG300-10 Multicast TV
schoep851
Hello together
I want to use Multicast TV VLAN with my SG300-10 to join Multicast Groups in different Data VLAN's.
It's working fine, but the problem is that it isn't possible to add all the Multicast Groups to the Multicast VLAN because each TV channel use other groups.
For me it's only to handle if I can use wildcards to add a specific range of multicast traffic to the Multicast TV VLAN.
Is that possible with that Switch?
Thanks for help.
jeffrrod
Level 4
Level 4
Dear Ephraim,
Thank you for reaching Cisco Small Business Support Community.
Please refer to the admin guide, p.228, for Access port Multicast TV VLAN configuration;
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
I hope that is that you were looking for and please let me know if there is any further assistance we may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
