SG300-10 - No routing between VLANs
Basic-Fit
I'm trying to setup an SG300-10 switch to route traffic between two VLAN's, but I don't get it to work properly. Here's  my setup with which I'm testing this:
  • Layer 3 mode is enabled
  • The switch has two VLANs:
    • VLAN 30 has IP address 10.30.250.21, mask 255.255.255.0
    • VLAN 32 has IP address 10.32.250.11, mask 255.255.255.0
  • All switchports are in access mode
  • Interface GE1 is a member of VLAN 32
  • Interface GE9 is a member of VLAN 30
  • In VLAN 32 I have a PC with IP-address 10.32.250.10, mask 255.255.255.0, gateway 10.32.250.11
  • In VLAN 30 I have a PC with IP-address 10.30.250.10, mask 255.255.255.0, gateway 10.30.250.21
Both PC's are able to ping the IP-address of the switch in their own corresponding VLAN, but they are also able to ping the IP-address of the switch in the other VLAN. However, they are not able to ping each other, while I can ping both PCs from the CLI of the switch.
No Internet access is needed in this setup, so I don't have to create a default route on the switch, it's just these two hosts that need to communicate with each other.
Here's the config:
config-file-header
switch92d92d
v1.4.0.88 / R800_NIK_1_4_194_194
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 30,32
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname switch92d92d
ip telnet server
interface vlan 1
 no ip address dhcp
 shutdown
interface vlan 30
 ip address 10.30.250.21 255.255.255.0
interface vlan 32
 ip address 10.32.250.11 255.255.255.0
interface gigabitethernet1
 switchport mode access
 switchport access vlan 32
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
 switchport access vlan 30
interface gigabitethernet10
exit
7 Replies 7
Aleksandra Dargiel
Hi Basic-Fit,
This seems to be related to windows firewall so please try to disable Windows firewall and test.
Aleksandra
It's not related to the Windows firewall. It is disabled by a GPO on our network and I can ping both hosts if I connect them to the same VLAN.
Regards, Leo.
Hi Leo,
Can you do packet capture on both PC to see what is missing arp or ICMP?
Aleksandra
Hi Aleksandra,
If it's ICMP related, that would mean that I should be able to use other protocols, but I'm not able to use SMB, HTTP and RDP either. ARP is layer 2 only, so I don't think it's ARP related either.
There must be something in the switch config that doesn't work properly.
Hi Leo,
Yes you are right for ARP if you can ping the other vlan interface thus default gateway ARP response has no issue. Since such a setup normally works and configuration is correct either it is something with the way it is tested or the devices used for testing. Unfortunately without packet capture I cannot say much more than that.
Aleksandra
While building a new test setup to do packet captures, suddenly it worked. I don't know what I've done different this time, but my problem's solved now. Thanks for you effort.
Leo.
Great! Thank you Leo for feedback.
