02-24-2016 07:33 PM
Having issues with machine pinging from VLAN. I can ping each VLAN from CLI on the switch. I can ping the VLAN IP from the workstation. When I try to ping outside it fails.
PRI-CORE-SG300-10#show run
config-file-header
PRI-CORE-SG300-10
v1.3.5.58 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
spanning-tree mode mst
vlan database
vlan 10,15,20,30,35,99
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname PRI-CORE-SG300-10
line console
no autobaud
exit
line console
speed 9600
exit
clock timezone " " -8
clock summer-time web recurring usa
sntp anycast client enable ipv4
sntp broadcast client enable ipv4
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server time.nist.gov poll
ip name-server 8.8.8.8 8.8.4.4
interface vlan 1
no ip address dhcp
interface vlan 10
name Data
ip address 192.168.10.1 255.255.255.0
interface vlan 15
name WiFi
ip address 192.168.15.1 255.255.255.0
interface vlan 20
name Lab
ip address 192.168.20.1 255.255.255.0
interface vlan 30
name SecCam
ip address 192.168.30.1 255.255.255.0
interface vlan 35
name GuestWiFi
ip address 192.168.35.1 255.255.255.0
interface vlan 99
name MGMT-VLAN
ip address 192.168.11.254 255.255.255.0
interface gigabitethernet7
no spanning-tree portfast
switchport mode access
switchport access vlan 20
interface gigabitethernet8
interface gigabitethernet9
shutdown
switchport access vlan 99
interface gigabitethernet10
exit
ip default-gateway 192.168.11.1
PRI-CORE-SG300-10#
02-29-2016 08:54 PM
- from switch do: ping <vlan_XYZ--interface_ip_address> source <vlan_10-interface_ip_address> count 10
If it goes everytime you have already inter vlan IP switching.
- What vlan is your workstation located at ?
from switch do:
show arp (look for your WS hw address and IP and vlan)
then do:
ping <WS-interface_ip_address> source <vlan_XX-interface_ip_address> count 10
if it doesn't go then you have a problem in the return of packets from WS to switch
- What are you trying to ping? all vlan ip addresses from WS-host machine at vlan 20? are you specifying the correct interface in the host?
- What is the IP configuration of the workstation? Dynamic(from where?)/Static DNS/no-DNS, netstat -rn, arp -a
- What's between your workstation and the switch? if you have a router you'll need to add a manual route to your vlan in the router
- How many paths are there to your workstation? disable spanning tree to see effects.
03-01-2016 08:00 PM
I would like to gather more information to help diagnose this issue. What outside IP address are you trying to ping from the host? Also, what IP address is configured on the host? What type of device is the host directly connected to? Are you using a layer 2 or layer 3 switch?
