SG300-10PP PoE switch acting up
night-fury
I have a cisco SG300-10PP (PoE) switch to which i have 7 Cisco AIR-CAP2702I-D-K9 wireless access points connected. one of the ports of the remaninig ports is connected to a core switch. The APs are being managed by Cisco WLC 2504.
Now this 10 port switch in question has been recently installed, a few days back. how can I check if the switch is fine. the reason being, till yesterday one of the APs connected on port 2 was not working. I ran the cable diagnostics from the switch for this port and received a message that there is impedance mismatch at a distance of x meters.
Here is the config (IPs changed)
v1.4.2.4 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname WifiPoESw
no passwords complexity enable
username xxxxxxxx password encrypted xxxxxxxxxxxxxxxxxxxxxx privilege 15
ip ssh server
ip ssh password-auth
snmp-server location d-wing
ip domain name xyz.com
ip name-server 192.168.0.3
interface vlan 1
ip address 192.168.0.64 255.255.252.0
no ip address dhcp
interface gigabitethernet1
spanning-tree portfast
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet9
power inline never
interface gigabitethernet10
power inline never
exit
macro auto processing type switch disabled
ip default-gateway 192.168.0.1
I swapped a few ports to check and now port 2 is working and AP on port 3 is not which was working fine earlier. I ran cable diagnostics on port 3 and it showed that cable is open at few meters !! here are the results from sh cable-diagnostics tdr
Port        Result           Length [meters]  Date
gi1         OK
gi2         OK
gi3         Open cable   19                       16-Feb-2016 9:38:08
gi4         OK                                           16-Feb-2016 9:40:22
gi5         OK
gi6         OK
gi7         OK
Can someone please help to determine how can I make sure that the switch is ok or not. its a new one purchased from vendor and has not been included in our cisco contract yet, so unable to get support.
intport1231
check your response in your other exactly identical discussion: https://supportforums.cisco.com/discussion/12920126/sg300-10pp-poe-problem
Basically you could have damaged it already.
