SG300-20 with hardware version V03??
frank57011
I'm looking for information about a SMB switch SG300-20 with version hardware V03 because I don't find any information about it on Cisco website.
Even the firmwares release notes for this family of switches clearly indicate that there are two revision of hardware V01 and V02, howevever mine is V03 as also written on the back of the unit PIN VID.
What are the: Total number of MAC addresses, total number of active VLAN's, total number of multicast groups for this revision of hardware??
And also is the firmware 1.4.0 compatible with this revision of hardware?
Can someone gently help me find an answer?
Many thanks
Answer from the product team:-
Total Number
of MAC
Addresses
Total Number
of Active
VLANs
Total Number
of Multicast
Groups
Sx300 in Firmware 1.4.0
HW VID=03
16K
4,094
1K
Thanks.
Yiu Kay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | Yiu Kay Lee | SMB Pre-Sales | yiulee@cisco.com | Phone +1 (855) 354-7776
Yiu Kay Lee
The 300 series datasheet data is also applicable to SG300 hardware version V03.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Internet Group ManagementProtocol (IGMP) versions 1, 2, and3 snooping
IGMP limits bandwidth-intensive multicast traffic to only the requesters; supports 1K multicast groups (source-specific multicasting is also supported)
MAC table
Up to 16K (16384) MAC addresses
VLAN
Support for up to 4096 VLANs simultaneously Port-based and 802.1Q tag-based VLANs MAC-based VLAN
Firmware 1.4.0 is compatible with this hardware version.
Yiu Kay Lee
Concentrix at Cisco
Thanks for your reply,
however can  you please give me some more informations about this V03 revision of hardware?
Following what is written in the release notes of the 1.4.0 firmware, different hardware revisions have different specs.
Release Notes for 200, 300, 500, and ESW2 Series Switches Software Version 1.4.0
"This firmware runs on two different versions of hardware for the 200 Series Smart Switches, and the 300 Series Managed Switches. There is a single version of hardware for the 500 and ESW2 series switches. The number of supported MAC Addresses, Active VLANs, and Multicast Groups will be different depending on which version of hardware you are using. Refer to the following table for details:"
Extract of table regarding Sx300 model
V1 versus V2 HardwareTotal Number
of MAC
Addresses
Total Number
of Active
VLANs
Total Number
of Multicast
Groups
Sx300 in Firmware 1.0.x
HW VID=01
8K256256
Sx300 in Firmware 1.1.x
and above.
HW VID=01
8K256256
and above
HW VID=02
16K4K1K
So my question regarding the the V03 revision is: what number of supported MAC Addresses, Active VLANs, and Multicast Groups does the HW VID=03 revision have?
Many thanks for your support
Total Number
of MAC
Addresses
Total Number
of Active
VLANs
Total Number
of Multicast
Groups
HW VID=03
16K
4,094
1K
Thanks.
Yiu Kay Lee
Concentrix at Cisco
