SG300-24P fan problem
timc995
I have a problem with a fan.  The fan is operational, but I get a ton of log entries and the system LED is blinking.  The firmware is 1.4.8.6, and the boot is 1.3.5.06
Any ideas what's going on?
2147483473 2018-Mar-16 00:19:44 Alert %Environment-A-FAN-STAT-CHNG: FAN# 1 status changed - not operational.
2147483474 2018-Mar-16 00:19:40 Informational %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - operational., aggregated (1)
2147483475 2018-Mar-16 00:19:04 Alert %Environment-A-FAN-STAT-CHNG: FAN# 1 status changed - not operational., aggregated (12)
2147483476 2018-Mar-16 00:18:52 Informational %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - operational., aggregated (11)
2147483477 2018-Mar-16 00:14:28 Informational %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - operational.
2147483478 2018-Mar-16 00:14:16 Alert %Environment-A-FAN-STAT-CHNG: FAN# 1 status changed - not operational., aggregated (1)
2147483479 2018-Mar-16 00:14:12 Informational %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - operational., aggregated (11)
2147483480 2018-Mar-16 00:13:28 Alert %Environment-A-FAN-STAT-CHNG: FAN# 1 status changed - not operational., aggregated (10)
Aleksandra Dargiel
Hi Tim,
You may need to contact Support Team to initiate replacement process.
Aleksandra
