Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3125 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4675 Views
  • 1 replies
  • 16 Helpful votes
Hi, After updating the firmware from 1.3.7 to 1.4.86, the switch is not recognizing any Ethernet connection to it. Also the reset button is not working after the upgrade. Any ideas would be useful.   Kind regards.
rickrodz by Level 1
  • 785 Views
  • 1 replies
Resolved! SG300-52 VLANs
Hi, I have 3 x SG300-52 in my network and I need make VLANs. In example VLAN10 on switch 1 and 3. How can I do connect switch 1>2 and 2>3 if on switch 2 there is no VLAN10? From router to switch1 I have port interface general tagged, i.e. port GE5 Ac...
JacekD by Level 1
  • 2267 Views
  • 11 replies
I bought a new SG300-10MPP to drive some Cisco WAP371 wireless units using POE+.  I setup the SG300-10MPP and connected it to my SG300-28 layer 3 switch.  When I tried to create a VLAN 2 access port the window blimps out using Microsoft Windows 10 an...
Lee Cox by Level 2
  • 782 Views
  • 2 replies
TL:DR; How do you enable PortFast on a SG250-26HP?   Full story: I have just installed a DoorBird doorbell, that has a IP camera, and have some problems. It gets power, but cannot access my LAN. Looking into the logs, it connects (see later in mail) ...
Sleepy by Level 1
  • 1274 Views
  • 2 replies
I have a problem with a fan.  The fan is operational, but I get a ton of log entries and the system LED is blinking.  The firmware is 1.4.8.6, and the boot is 1.3.5.06 Any ideas what's going on?   21474834732018-Mar-16 00:19:44Alert%Environment-A-FAN...
timc995 by Level 1
  • 2659 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
