SG300-28P: POE power drops every several minutes
richlafferty
Hi all,
We have an SG300-28P which, at intervals between 5 and 30 minutes or so, drops power to all of its POE-powered ports and then immediately restores power. The switch logs nothing when this happens other than recording that the ports went down and back up, even with debug logging enabled. Non-POE ports are not affected.
When the problem started there were only four POE-powered devices on the switch and we are far under our power budget. (While testing I added a fifth device, see below.)
Not all combinations of devices cause the drops to occur -- specifically, it looks like having devices on ports near each other causes the drops. When the drops occur, the absent counters of all of the POE devices increment. I noticed this earlier thread here seemed similar:
https://supportforums.cisco.com/thread/2165089
but in that case, he got no power at all in the adjacent configurations, instead of having it drop every several minutes.
I'm running
sw06#sh ver
SW version    1.1.2.0 ( date  12-Nov-2011 time  23:34:26 )
Boot version    1.1.0.6 ( date  11-May-2011 time  18:31:00 )
HW version    V02
I have the new 1.2.2.7.6 firmware ready to go, I'll update this when I have a chance to test it. Unfortunately it is a production switch, but it's one with relatively few devices on it so far. If need be, I've got an sf300-48p I can swap in to dedicate this sg300 to testing.
Thanks for anything you might suggest.
Here's the details:
-  "Phone" is an Avaya 4610SW or 5610SW IP phone (class 2)
- "Watchdog" is a IT Watchdogs Watchdog 100 environmental monitor (class 0)
- "WAP" is a Cisco WAP4410N (class 3)
First failing combination:
gi10 phone #1
gi22 phone #2
gi23 watchdog
gi24 wap
would cause POE power to drop on all those ports every 5-30 minutes.
I turned off Green Ethernet entirely -- no change.
Then did the following tests:
1. "power inline never" on gi23 and gi24: problem went away
2. "power inline auto" on gi23 and gi24:  problem came back
3. "power inline never" on gi23 only:     problem went away
4. "power inline auto" on gi23:           problem came back
5. "power inline never" on gi24 only:     problem went away
6. "power inline auto" on gi24:           problem came back.
I left gi23 powered down overnight and it was stable: made it ~10h without any issues.
This morning tried the following configs:
08:54 - worked fine
gi4 watchdog
gi10 phone #1
gi22 phone #2
gi24 wap
10:31 - added another phone, problem came back
gi4 watchdog
gi10 phone #1
gi22 phone #2
gi23 phone #3
gi24 wap
10:43 - moved phone #3 to gi11 (adjacent to gi12) -- problem continued
gi4 watchdog
gi10 phone #1
gi11 phone #3
gi22 phone #2
gi24 wap
11:00 - moved phone #3 to gi8 -- problem continued
gi4 watchdog
gi8 phone #3
gi10 phone #1
gi22 phone #2
gi24 wap
11:31 - moved phone #3 to gi14 -- problem went away
gi4 watchdog
gi10 phone #1
gi14 phone #3
gi22 phone #2
gi24 wap
and that's where we've left things right now, been stable for about four hours.
All of the following outputs are from the latest (11:31) config.
sw06#show power inline
Port based power-limit mode
Unit  Power  Nominal Power   Consumed Power   Usage Threshold   Traps
1     On      180 Watts     18 Watts (10%)         95         Disable
  Port      Powered Device         State          Status    Priority   Class
  gi1                               Auto        Searching     low     class0
  gi2                               Auto        Searching     low     class0
  gi3                               Auto        Searching     low     class0
  gi4                               Auto            On        low     class0
  gi5                               Auto        Searching     low     class0
  gi6                               Auto        Searching     low     class0
  gi7                               Auto        Searching     low     class0
  gi8                               Auto        Searching     low     class0
  gi9                               Auto        Searching     low     class0
  gi10                              Auto            On        low     class2
  gi11                              Auto        Searching     low     class0
  gi12                              Auto        Searching     low     class0
  gi13                              Auto        Searching     low     class0
  gi14                              Auto            On        low     class2
  gi15                              Auto        Searching     low     class0
  gi16                              Auto        Searching     low     class0
  gi17                              Auto        Searching     low     class0
  gi18                              Auto        Searching     low     class0
  gi19                              Auto        Searching     low     class0
  gi20                              Auto        Searching     low     class0
  gi21                              Auto        Searching     low     class0
  gi22                              Auto            On        low     class2
  gi23                              Auto        Searching     low     class0
  gi24            -                 Auto            On        low     class3
-- watchdog:
sw06#show power inline gi4
Power limit (for port power-limit mode): 15.400W
Port Status:               Port is on - valid resistor detected
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            4
Invalid Signature Counter: 0
sw06#show interfaces advertise gi4
Port: gi4
Type: 1G-Copper
Link state: Up
Auto negotiation: Enabled
                                  1000f  1000h  100f  100h  10f  10h
Admin Local link Advertisement    yes    no     yes   yes   yes  yes
Oper Local link Advertisement     yes    no     yes   yes   yes  yes
Oper Remote link Advertisement    no     no     yes   yes   yes  yes
Priority Resolution               -      -      yes   -     -    -
-- phone:
sw06#show power inline gi10
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            465
sw06#show int adv gi10
Port: gi10
Type: 1G-Copper
Link state: Up
-- phone:
sw06#show power inline gi14
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            0
sw06#show int adv gi14
Port: gi14
Type: 1G-Copper
Link state: Up
sw06#
-- phone:
sw06#show power inline gi22
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            591
Invalid Signature Counter: 166
sw06#show int adv gi22
Port: gi22
Type: 1G-Copper
Link state: Up
-- was watchdog, now empty:
sw06#show power inline gi23
Port Status:               Port is off - detection is in process
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            587
-- wap:
sw06#show power inline gi24
Overload Counter:          0
Short Counter:             0
Denied Counter:            0
Absent Counter:            607
Invalid Signature Counter: 3
sw06#show int adv gi24
Port: gi24
Type: 1G-Copper
Link state: Up
Oper Remote link Advertisement    no     no     yes   no    no   no
Other useful bits:
sw06#show spanning-tree active
Spanning tree disabled (BPDU flooding) mode RSTP
Default port cost method:  long
sw06#sh ver
HW version    V02
Hi Rich, reference this picture I just drew- This is a rough interpretation of how a 24 port switch has for guts. Each + block represents a transformer. The corresponding numbers below represent the port bank which corresponds to the transformer. Of course POE MODULE is clearly identified. Each POE module services 12 ports.
I think you have a completely different issue. If the POE is working for 5-30 minutes, it may be a layer 1 issue (bad wires) or a different condition, perhaps equipment being disturbed. If the switch is at fault, it would seem more likely to be a defective than a buggy unit.  I have done a lot of extensive research on how the switch ASIC, transformer and POE modules work in cohesion.
Quite frankly, I think you should upgrade to the 1.2.7.76 firmware, factory reset the unit and test any ports you'd like using the same equipment. If the POE keeps dropping off every 5-30 minutes and you are absolutely positive it is not a layer 1 issue or a configuration issue on your products, I'd just replace the switch.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
6 Replies 6
Tom Watts
Hello Rich, the case I created for the other gentlemen, John White is 622799757. Currently, this case status is pending more testing from the development team. However, his scenario is using Ruckus 7982 AP.
The important thing to note I think is how the port transform and poe modules interact. The port transformer services 4 ports
1,2,13,14
3,4,15,16
etc
In theory you should be able to connect every other port without issues such as;
1, 3, 5, 7
13, 15, 17, 19
etc
To keep this very simple;
Connect phone #1 to port 1
Connect phone #2 to port 2
Connect phone #3 to port 13
Connect ap #1 to port 14
Do these devices 1 at a time until they are fully powered. Do not connect them all at the same time.
What is the result?
-Tom
Did so (with ports 3, 4, 15, 16 -- port 1 is a trunk to another switch so I didn't want to repatch it.)
I haven't seen POE power bounce in the last ten minutes or so. I did notice one slight anomaly when the AP was coming up:
11-Sep-2012 17:05:41 %LINK-I-Up:  gi16
11-Sep-2012 17:05:46 %LINK-W-Down:  gi16
11-Sep-2012 17:05:48 %LINK-I-Up:  gi16
11-Sep-2012 17:05:50 %LINK-W-Down:  gi16
11-Sep-2012 17:05:51 %LINK-I-Up:  gi16
but I suspect that might just be a weirdness of the AP. I'll let this soak overnight -- I'm about to head out for the day, and sometimes the cycle is as long as a half hour when it does happen. If there's something else you'd like me to test following this test, let me know, and I'll provide that tomorrow morning along with whether or not this was stable overnight.
The watchdog is currently disconnected, so these four are the only POE devices on the switch.
I'm out of the office for most of tomorrow.
Hey Tom,
The switch was stable overnight with three phones and the WAP in 3, 4, 15, 16.  The Watchdog is still disconnected. What's the next step?
-Tom
Hi Thomas,
Upgrading the firmware seems to have done it. We've been stable (knock on wood!) for about a month now. Thanks for your help!
myanuary
yesterday, i've an issue like that on catalyst 4507...
two ip phone suddenly "off", and when i try to connect it on another port, it's "on" again..
the poe status is auto...
so i try to connect it to my pc, and the link is up, then i connect it again to ip phone again and magically it's "on" again...
i don't know why suddenly the poe "die" and "live" again, i am still curious if this happen again..
what a strange problem...
