SG300-28P
noesberger
I have a problem in my home network and I'm not able to find the root-cause.
Sometimes during the day it happens, that I can't connect to the internet. The problem is that I can't ping the Cable Modem from my PC and the SG300 (acting as default-gw) has a very high latency on the ping and often also complete packet loss.
I have some sonos devices in the network, some of them are connected with cable and i found the following article: https://sonos.custhelp.com/app/answers/detail/a_id/2129/~/sonos-stp-cisco-switch-settings. I've modified the settings as described, but it's still the same problems.
Sometimes I'm still able to connect with ssh to the switch. What should I test to find the root-cause of the problem. I've checked "show spanning-tree" but no port is shown as blocked.
Thanks for any help or ideas.
Michal Bruncko
Level 4
Level 4
high latency for pinging your default gw could point to broadcast storm in your network. I am recommending you to connect to your switch via console and check system log. If ssh is working, you can use ssh then.
Do you have latest version of your switch firmware? Versions 1.4.x.x supports loopback detection and stp loopback detection. They are both disabled by default so I recommend you to enable them both.
But firstly focus on system log output and perhaps on show interface counters output to see ratio between unicast vs. multicast/bcast packets over each interface.
Thanks for your reply.
The installed firmware is 1.4.1.3.
When I type "show logging" I can't see any special log entry. Is there an other command I can use to see more logging details?
Here the output of show interface counters:
Port       InUcastPkts  InMcastPkts  InBcastPkts    InOctets
      gi1           63805         214          8008       7316836
      gi2             0            0            0            0
      gi3          9775099        2882        19190      3999817392
      gi4             0            0            0            0
      gi5             0            0            0            0
      gi6             0            0            0            0
      gi7             0            0            0            0
      gi8             0            0            0            0
      gi9             0            0            0            0
      gi10            10           0          25862       2017636
      gi11          375989       419510       15211      690009328
      gi12            0            0            0            0
      gi13           135          185          125         143844
      gi14          13525         4256         899        5611210
      gi15          37795          0          70491       10365199
      gi16            0            0            0            0
      gi17          30623         5551         1762       6244427
      gi18            0            0            0            0
      gi19            0            0            0            0
      gi20         11037304       3185         563      12960641550
 Port       OutUcastPkts OutMcastPkts OutBcastPkts  OutOctets
      gi1           32692        492637       139697     549833649
      gi2             0            0            0            0
      gi3          11453674      489993       128532    13646568737
      gi4             0            0            0            0
      gi5             0            0            0            0
      gi6             0            0            0            0
      gi7             0            0            0            0
      gi8             0            0            0            0
      gi9             0            0            0            0
      gi10           8465        492987       121868     546760532
      gi11          476906       70455        131731     105463110
      gi12            0            0            0            0
      gi13           219          199          251         94458
      gi14          18179        53950        48626       13239366
      gi15          48651        510732       77248      574120960
      gi16            0            0            0            0
      gi17          48245        505206       146007     604505222
      gi18            0            0            0            0
      gi19            0            0            0            0
      gi20         9335060       507583       147216     4487544046
counters looks fine.
what is logged during time when issue happen? anything?
you can also check switch uptime with "show system" command and confirm if switch is stable without accidental reboots during day.
one more question: during that issue you said that you observing high latency while you ping your modem. what about other devices connected to this switch? are you observing same latency during issue? if there is latency only toward your modem then probably your switch is OK and affected/utilized device is modem (attack from outside?).
