SG300-52 with limited internet access
Lars-Inge
Hi all
Hopefully someone can help me out with an issue. I'm relatively good with general IT, included networks, but this switch makes me think I don't know sh..
My setup is:
Router/AP (in the living room): 10.0.10.1
Wireless Access Point (basement): 10.0.10.2
Cisco SG300 (basement): 10.0.10.254 (connected to the wireless access point via cable on GE49 (Trunk)
I have set up several VLAN with different types of machines (internal servers, development servers, production servers (for testing) and some NAS devices. I have left the deault VLAN 1 for now, and the IP 10.0.10.254 is assigned to this VLAN.
If I log into the switch (CLI or WEB interface) I have can ping both IP addresses and domain names, no problem. I can ping the router (10.0.10.1) from ALL computers/servers connected to any of the VLAN's.
Computers/servers connected to any other VLAN than the default has NO INTERNET ACCESS, nor with ping or with other services.
I have static routes on the router that goes to each VLAN, and I can access machines on all VLAN's from my laptop that is on wireless network (same subnet as VLAN 1).
I cannot figure this one out, and hope there is someone out there that might help me out and point me in the right direction. I'm quite sure it something stupid and easy that I have forgotten.
By the way, I'm not very much into switches...
Best regards
Lars-Inge
18 Replies 18
pwwiddicombe
Level 4
Level 4
What gateway do you have assigned for all the non-functional VLAN's you've created; and what routing protocol are you running?  Where to the IP addresses come from for those devices (presumably some form of DHCP), but it has to include what the (reachable) gateway should be ?
Sorry, forgot a couple of things...
The switch is set to L3 mode.
All IP addresses are fixed IP's and all gateways are set to the VLAN IP, i.e., 10.0.30.1 for VLAN 30.
Routing protocol?
@Lars-Inge
 It could be a NAT issue. The router on this case, need to receive the traffic from the switch and NAT it in order to sent it to the internet.
If you are doing NAT, then this could be a routing problem. As the switch is a layer3 device, as you mentioned, you can have one default route on the switch sending everything to the router. On the router you must have a default route sending everything to your ISP.
 then, you need specific routes on the Router sending the traffic back to the switch.  Assuming the communication between router and switch is a Layer3 point to point.
If the communication between router and switch is via trunk, then you need to have the vlans create on both device and the gateway must be the router.
This is where my knowledge is lacking, but how can it be NAT if everything is working fine on VLAN 1?
Also, as mentioned, the routes back to the switch is set up for all VLAN's on the router and I can access ALL computers on ALL VLAN's from my laptop, hence I cannot see that there is a problem with communication between the switch and the router.
The router is doing NAT by default, and again, everything is working perfectly on VLAN 1.
I am focous on the communication between the hosts and the internet.  The fact of vlan 1 is working for NAT, does not tell what the problem is. IF the NAT was configured for the vlan1, it will work but what about the other vlans? NAT can be configured on per vlan/network basis.
The issue seems to be related to NAT or routing between VLANs, specifically for internet access. Since VLAN 1 works perfectly and the router is handling NAT by default, there are a few potential areas to investigate:
1. NAT Configuration for Other VLANs:
  • While your router is doing NAT for VLAN 1, it may not be configured to NAT traffic from other VLANs. Make sure the router's NAT configuration includes the VLANs you’ve set up. NAT rules or access control lists (ACLs) need to allow outgoing traffic from all VLANs to the internet.
Check:
  • On your router, ensure there’s a NAT rule that includes all VLAN interfaces (e.g., 10.0.20.0/24 for VLAN 20, 10.0.30.0/24 for VLAN 30, etc.).
2. Inter-VLAN Routing:
  • The fact that you can ping devices across VLANs from your laptop suggests that inter-VLAN routing is working. However, if the switch (in L3 mode) handles inter-VLAN routing, check whether traffic from non-VLAN 1 networks is being properly routed to the router for internet access.
Check:
  • On your Cisco SG300, ensure you have proper default routes (such as ip route 0.0.0.0 0.0.0.0 10.0.10.1) in place for each VLAN. Each VLAN should have a route that points traffic destined for the internet to the router.
3. VLAN Tagging and Trunk Configuration:
  • Since VLAN 1 works but other VLANs don't, verify that your trunk port (GE49) between the wireless access point and the switch is allowing the VLANs. Improper VLAN tagging or trunk misconfiguration can prevent certain VLAN traffic from reaching the router.
Check:
  • Ensure the trunk on your switch allows all relevant VLANs and that the access point and router can handle traffic tagged for those VLANs.
4. Firewall or Access Lists on the Router:
  • The router may have firewall rules or ACLs preventing certain VLANs from accessing the internet.
Check:
  • Review the router's firewall or ACL settings to ensure they allow outbound traffic for all VLANs.
5. DNS Configuration:
  • Verify that devices in other VLANs are configured with proper DNS settings. Incorrect DNS settings may prevent the resolution of domain names, even if internet connectivity is otherwise functional.
Check:
  • Ensure that all VLANs have a working DNS server configuration. Either point them to a public DNS server (like 8.8.8.8) or to the router's IP as the DNS resolver.
Steps to Diagnose:
  1. From a device in one of the non-VLAN 1 networks, try to ping the router (10.0.10.1).
  2. From the same device, try to ping an external IP like 8.8.8.8. If this works, the issue is DNS.
  3. If you cannot ping external IPs, check your NAT and routing configuration on the router.
Thanks Maher, really appriciate a thorough chec list.
Will have a look tomorrow...I managed to lock myself out from the switch when I tried some ACL rules...
Lars-Inge
Hi all
I have done some more testing and troubleshooting without much success, and in order to get it running I have moved the one server I'm working on to VLAN 10.
- I have checked static routes on the router, and there is one route for each VLAN pointing to VLAN 10 on the switch.
- On the switch I have the following routes:
0.0.0.0/0 10.0.10.1
10.0.10.0/24
10.0.20.0/24....
I cannot find any way to put in a "Next hop" on the VLAN routes. Is this maybe the problem?
If this is the case, what would be the correct command in CLI to create these?
- VLAN Tagging/Trunk
Have tried different options here without any change. Currently port 49 is set to "Untagged" for VLAN 10 and "Tagged" for all other VLAN's, and it is a trunk port.
- Router Firewall is enabled, but no rules. I have also tried to disable it without any change.
- DNS is set globally on the switch, and i can ping the outside world from the switch, both by IP and domain name, no isses there.
Funny thing is that I can access a webserver on VLAN 30 from the internet unless, but no access from the webserver to the internet...
I have to say that I'm lost, completely.
If anyone feel like having a look at my config file, please let me know, I'm getting desperate
Hi Lars,
You've already configured much of the network correctly, but there are a few areas that might need adjustments to allow internet access for devices on VLANs other than VLAN 1. Let's walk through a few possible solutions:
1. Routing and Default Gateway on the VLANs
  • Ensure that each device on the different VLANs has its gateway set to the corresponding VLAN interface IP on the switch (SG300).
  • For example, devices in VLAN 10 should use 10.0.10.254 as their gateway, devices in VLAN 20 should use 10.0.20.254, and so on. This ensures the devices are routing traffic through the switch.
2. Switch Routing and Default Route
  • The switch's routing table needs to point back to the router (10.0.10.1) for internet traffic.
  • You already mentioned that you have a default route (0.0.0.0/0) pointing to 10.0.10.1, which is correct.
  • However, you might want to double-check if Inter-VLAN routing is fully enabled on your switch for all VLANs, especially for VLANs other than VLAN 1. This feature is necessary for routing between VLANs and to external networks.
3. NAT Configuration on the Router
  • Ensure that NAT is configured properly on the router to allow internet access for traffic coming from different VLANs.
  • Depending on your router, you may need to configure NAT rules for each VLAN subnet to allow internet-bound traffic. For example, a rule to allow traffic from the 10.0.20.0/24, 10.0.30.0/24, etc., subnets to be translated and sent to the internet.
4. VLAN Trunking on Port 49
  • Port 49 is set up as a trunk port, but it’s crucial that it's configured correctly for VLAN tagging.
  • The "Tagged" setting for VLANs other than VLAN 10 seems fine, but make sure that all VLANs that need to pass through this port are properly tagged. VLAN 10 being "Untagged" should be fine if it's the native VLAN, but confirm that other VLANs are tagged appropriately and that your trunk configuration matches the settings on both the access point and the router.
5. Firewall and ACLs
  • Even though you've disabled the firewall on the router for testing, it may still have default rules blocking traffic from non-VLAN 1 subnets to the internet.
  • Check if there are any Access Control Lists (ACLs) or firewall policies that might be blocking outbound traffic for these VLANs.
6. CLI Commands for Routing on the Switch
If the switch does not allow you to specify the "Next Hop" for each VLAN route (which is usually necessary when performing routing duties), you may not need to configure individual next hops if the switch is aware of the default route.
However, on some switches, you can set up routes for specific VLANs using commands like:
ip route 10.0.10.0 255.255.255.0 10.0.10.254
ip route 10.0.20.0 255.255.255.0 10.0.20.254
This tells the switch how to handle traffic for each VLAN. Ensure the switch has static routes for each VLAN pointing to their corresponding IP range.
7. Debugging
  • Ping Tests: Try pinging 8.8.8.8 (Google DNS) from a device on a VLAN like VLAN 10 to see if you can reach an external IP.
  • Traceroute: Run a traceroute from a VLAN device to an external IP and see where the traffic gets stuck.
Once you've checked and configured these aspects, your VLANs should be able to route internet-bound traffic properly.
Hello Maher
Sorry for the late reply, I have been away for work a few weeks now and haven't been able to look into this until now. Thanks for very specific and useful information, appreciate that.
I have been thru the config again and checked what I can check.
Checked, doublechecked, and even tried different IP's just to be sure I didn't mess it up. It seems to be correct on all clients, but no luck on accessing internet.
My understanding is the L3 mode is what is needed on this switch for inter VLAN routing, and it is set to L3 mode. Also, I can access ALL clients from any other client on ALL VLAN's. No problem there at all.
This kind of tell me that inter VLAN routing is OK, but again, I'm not that familiar with switches and VLAN's, hence I'm trying to learn it
I have a static route for each VLAN configured on the router. I'm able to ping all connected clients from the router, included those that are on the different VLAN's on the switch. Again, this tells me that the VLAN's config on the router is correct.
Ping from router to ALL clients are OK as well as from ALL clients to the router IP. I can ping both the internal IP (10.0.10.1) on the router and the WAN IP supplied from the ISP.
All VLAN's, except VLAN 10, is tagged for port 49. I even tried "tagged" on VLAN 10, but then I lost the connection with the switch
Firewall and ACLs
I have checked every possible config on the router, and I cannot find anything blocking access to the VLAN's. Not saying that isn't the problem thought...
I might need to look into another router if I want to get this working.
I might be getting somewhere here. If I disconnect all clients, I can add a static route for the VLAN's, i.e., "configure" -> "interface vlan 40" -> "ip route 10.0.40.0. 255.255.255.0 10.0.10.1" without any error message. In the WEB GUI this route shows up as remote and static.
However, as soon as I connect a client to the port, it changes to local and directly connected. IS this where something is going wrong?
Debugging
I can ping external address from the switch (VLAN 10) and also from other clients on VLAN 10.
Clients on other VLAN's can ping their gateway, i.e., 10.0.30.254 as well as both internal and external address on the router, but nothing on the outside.
On your last comment, I can set next hop on the VLAN's as long as no clients are connected to the VLAN. As soon as I connect a client it changes to local and directly connected and the next hop disappear.
Hi Lars,
It would be better if you can share the configurations to be revised
Added the config. I have cleared most of the config and are currently only focusing on VLAN 30 to try and get that running before I start on the other ones.
As you can see, I have removed some information that is not relevant (some of the ports that are not configured and the SSH information.
Really appreciate your help on this.
Lars
Hi Lars,
From the configuration you've shared, everything seems mostly aligned for VLAN 30. Here are a few things to check or adjust to help resolve the issue of no internet access from VLAN 30:
1. VLAN IP Assignment:
You have assigned IP addresses to VLAN 10 (10.0.10.254/24) and VLAN 30 (10.0.30.254/24). This looks fine. Each VLAN should be using its respective gateway for routing within the subnet.
2. Default Gateway and Routing:
You have set the switch's default gateway as 10.0.10.1, which is correct as it’s your router. The ip route commands you added should point traffic from VLAN 30 to the router (10.0.10.1), so this looks good too.
The problem could be with the NAT on the router. Ensure the router is NATting traffic from VLAN 30 (10.0.30.0/24) to the internet. Typically, routers only NAT traffic from the default VLAN or main subnet (here, VLAN 10). You need to check the router’s NAT settings and ensure it includes the VLAN 30 subnet in the NAT rules.
3. Check Trunking for Port 49:
Port 49 is configured to allow VLAN 30 in the trunk, which is correct. However, double-check that:
  • The trunk port (GE49) on your Wireless Access Point also has VLAN 30 allowed in its configuration.
  • VLAN traffic for VLAN 30 is tagged correctly, and the AP understands and forwards the traffic as intended.
4. Firewall on Router:
Ensure that there are no firewall rules on the router that block traffic from VLAN 30 from accessing the WAN interface or performing NAT. You may want to temporarily disable firewall rules or inspect them closely to ensure VLAN 30 is allowed.
5. NAT for VLAN 30 on Router:
If VLAN 30 clients can reach internal networks (like VLAN 10), but not the internet, it's almost certainly related to how NAT is configured on your router. Make sure that your router is configured to NAT all outgoing traffic from VLAN 30 to the WAN interface.
6. Test the VLAN Route:
  • Try manually pinging an external IP (e.g., 8.8.8.8) from a device on VLAN 30. This helps test whether DNS is the issue or if the traffic isn’t getting NATed properly.
  • If pinging by IP works but not by name, the problem could be DNS-related (check DNS settings on VLAN 30 clients).
7. Access Control List (ACL):
Check whether you have any ACLs on the switch or router that might restrict internet access for VLAN 30.
8. DHCP (If Applicable):
If you’re using DHCP for VLAN 30, ensure that the router is providing the correct gateway and DNS information for clients on this VLAN.
Hi Maher
I currently have one NAT for VLAN 30 on the router, and that is "Destination: 10.0.30.0/24" and "Next hop: 10.0.10.254".
With this I have access to clients on VLAN30 from VLAN10, any other setting breaks the connection between VLAN10 and VLAN30.
Maybe I need to look for another router...
