SG300 And SVI Routing...
Eric Wilkins
I'm looking to connect a switch to my home ASUS router and I know the router doesn't support direct VLAN tagging.
So my solution is to buy a SG300 and do the L3 routing and VLAN tagging directly on that instead.
My questions are the following:
1. Does the SG300 support SVI capability?
2. Does the SG300 have a layer 3 mode? I looked in the admin guide but couldn't find if that's supported.
Thanks in advance for the assistance.
Ingrid Aragon
Eric,
As manage device, yes it has Layer 3 mode. Check this in the system summary, if you found that it is on L2 you can go to Administration > System settings.
I hope you found this information helpful.
I have a an ASUS AC88U router which does not directly support VLAN tagging. I want to be able to circumvent that "lack of functionality" by introducing a Cisco SG300 switch between that router and a ESXi server with 6 physical NIC cards. The goal is to have at least 4 of the NIC cards on a separate VLAN for essentially training purposes within my home lab environment.
My thoughts are the following:
1. Connect the SG300 to my ASUS Router by way of a ROUTER on a Stick connection.
2. Have the ports for each of my NIC cards on the server connected to the SG300 as a individual broadcast domain with a VLAN and IP assigned (L3).
My questions and/or concerns are do you think this will work? I know the server NIC cards connected to the SG300 will work, but how to get that traffic successfully passed to the ASUS Router, not directly supporting VLANs is a concern.
Any thoughts or suggestions would be greatly appreciated. My goal is simply to use VLANs within my environment with a home router that doesn't directly (not part of the firmware build) support VLANs.
ASUS Router ----- > Cisco SG300 ----- > Server
Thanks!
