Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3576 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5265 Views
  • 1 replies
  • 16 Helpful votes
Installed one of these at a client, and cannot access the PoE management on the Web interface. Thought perhaps it was the browser preventing, but the same issue occurs in Chrome, Edge, IE and Firefox.  Switch currently running 1.0.0.17 firmware, but ...
titanpcs by Level 1
  • 2034 Views
  • 8 replies
Hai , Cisco Catalyst 2960 series switch showing " Press Return to get started " when connect using Teraterm . using this message not possible to enter in switch settings .How to solve this issue or skip from this message . Error message has been upl...
Version 12.2(44)SE5"WS-C2960G-24TC-L" interface GigabitEthernet0/6 switchport access vlan 91 switchport mode access switchport voice vlan 93 switchport port-security maximum 2 switchport port-security switchport port-security aging time 10 storm-co...
Hi, all           "Leap seconds" are extra seconds that are added or removed to keep Civil Time, which is based on Universal Coordinated Time (UTC), within 0.9 seconds of the Earth's rotational time (UT1). The next leap second will be introduced in ...
360rundll by Level 1
  • 404 Views
  • 0 replies
Hello, I have configured a DHCP server with IP's for 3 VLANs: 192.168.20.1 192.168.30.1 192.168.40.1 On my SG300 I have configured Option 82, DHCP Relay and the IP addresses of my DHCP server which my subnets are on 3 different NICS on the server eac...
I've got several Cisco switches deployed throughout several locations that seem to randomly lock up and reboot. They are the SG300 series in 10 and 20 port models. The error in the flash logs is: Emergency%SYSLOG-F-OSFATAL:   FATAL ERROR: GOAH: ABORT...
Hi, I have a forgotten password issue on a c3750x switch.  I have tried the password recovery procedure pressing mode upon inserting the power cable but the switch is not recognising it.  I wonder if the mode button is faulty??  Also, I have noticed...
deskguest by Level 1
  • 589 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
