SG300 in routing mode, ACL does not work
sibekotech
Hi all.
U.P.D. Ok, problem is solved, if workaround can be seen as a fix. It's a bug unfortunately, if You check my config, You'll see that I created two ACL rules with some ACE's and bind them to Vlan's, those Vlan's is trunked to other switch thru Port-Channel. After every reload of switch, something going wrong, so ACL's stop working, partially, but if I remove and add back port from/to Port-Channel, all goes to normal state. I can't figure how to send a bug report, so if someone can help me with, I'll appreciate that.
What I'm trying to do, is to get basic filtering on SG300, that configured in router mode.
config-file-header
sg300-csw01-nya
v1.4.1.3 / R800_NIK_1_4_194_194
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
no cdp run
spanning-tree priority 4096
port jumbo-frame
lacp system-priority 10
vlan database
vlan 10,20,30,40,50,60
exit
voice vlan state disabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
port-channel load-balance src-dst-mac-ip
no lldp run
loopback-detection enable
ip dhcp relay address 172.16.40.203
ip dhcp relay enable
no boot host auto-config
no boot host auto-update
no bonjour enable
ip access-list extended ac-wfnw
permit udp 172.16.50.0 0.0.0.255 any 172.16.40.203 0.0.0.0 domain ace-priority 10
permit tcp 172.16.50.0 0.0.0.255 any 172.16.40.203 0.0.0.0 domain ace-priority 20
deny ip any 172.16.20.0 0.0.0.255 ace-priority 1000
deny ip any 172.16.40.0 0.0.0.255 ace-priority 1010
deny ip any 172.16.60.0 0.0.0.255 ace-priority 1020
permit ip any any ace-priority 2000
exit
ip access-list extended ac-canw
permit ip 172.16.60.51 0.0.0.0 172.16.20.0 0.0.0.255 ace-priority 10
deny ip any 172.16.50.0 0.0.0.255 ace-priority 1010
exit
hostname sg300-csw01-nya
encrypted radius-server host radius.corp.sibekotech.ru key ---
radius-server host source-interface vlan 20
aaa authentication login default radius local
no passwords complexity enable
passwords aging 0
username cisco password encrypted --- privilege 15
username zanswer password encrypted --- privilege 15
ip ssh server
ip ssh password-auth
snmp-server server
snmp-server engineID local 800000090308d09f71612a
snmp-server view noc iso included
snmp-server view noc ifName.3000 excluded
snmp-server view noc ifName.7000 excluded
snmp-server view noc ifName.20000 excluded
snmp-server view noc ifName.100000 excluded
snmp-server view noc ifName.100009 excluded
snmp-server view noc ifName.100019 excluded
snmp-server view noc ifName.100029 excluded
snmp-server view noc ifName.100039 excluded
snmp-server view noc ifName.100049 excluded
snmp-server view noc ifName.100059 excluded
snmp-server group noc v3 priv read noc
encrypted snmp-server user noc noc v3 auth sha --- priv ---
no ip http server
no ip http secure-server
clock timezone YEKT +5
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server ntp.corp.sibekotech.ru poll
sntp source-interface vlan 20
ip domain name corp.sibekotech.ru
ip name-server  172.16.40.203
interface vlan 1
 no ipv6 address autoconfig
 no ipv6 enable
 shutdown
interface vlan 10
 name vl-blhl
interface vlan 20
 name vl-mgmt
 ip address 172.16.20.254 255.255.255.0
interface vlan 30
 name vl-ronw
 ip address 172.16.30.253 255.255.255.252
interface vlan 40
 name vl-srnw
 ip address 172.16.40.254 255.255.255.0
interface vlan 50
 name vl-wfnw
 ip address 172.16.50.254 255.255.255.0
 service-acl input ac-wfnw
interface vlan 60
 name vl-canw
 ip address 172.16.60.254 255.255.255.0
 service-acl input ac-canw
interface gigabitethernet1
 shutdown
 description not-conf
 spanning-tree link-type point-to-point
 spanning-tree guard root
 switchport mode access
 switchport access vlan 10
interface gigabitethernet2
 shutdown
interface gigabitethernet3
 shutdown
interface gigabitethernet4
 shutdown
interface gigabitethernet5
 shutdown
interface gigabitethernet6
 description crt01-ge01
 spanning-tree portfast
 spanning-tree bpduguard enable
 switchport access vlan 30
interface gigabitethernet7
 shutdown
 description srv01-eth1
 lacp port-priority 10
 channel-group 2 mode auto
interface gigabitethernet8
 shutdown
 description srv01-eth2
interface gigabitethernet9
 shutdown
 description asw01-gi01
 channel-group 1 mode auto
interface gigabitethernet10
 shutdown
 description asw01-gi02
interface Port-channel1
 speed 1000
 description asw01-po1
 switchport trunk allowed vlan add 20,40,50,60
 switchport trunk native vlan 10
interface Port-channel2
 speed 1000
description srv01-bond0
 switchport trunk allowed vlan add 40
interface Tunnel 1
 shutdown
exit
ip default-gateway 172.16.30.254
I've created one ACL with one ACE and binded it to Vlan 50. But problem is, that I can ping some hosts, how traffic can flow thru interface if all traffic is blocked on it?!
Wireless AP connected to SF300, that configured in switch mode, so it can't do any routing. I do not understand how and I can't find a way to troubleshoot this behavior.
sibekotech
I've did some research today and find some interesting things. First, You can't mirror Port-Channel or port in it, second ACL start to work if I remove one of ports from Port-Channel and work even if I'll add them back after that.
