Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3500 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5170 Views
  • 1 replies
  • 16 Helpful votes
Hi, I'm struggling with running a SNMP Walk against a SG500-28P stack. I wish to retrieve: CPU Utilsation Mac-address table count Port Cahnnel utilisation. Switch Stack member state  When I run the walk using 1.3.6.1 all I get is basic system info...
I am trying to figure out if option 82 should be used or not.   We have a SG300-52 with multiple switches attached. Most of those are a single vlan.   Some have smart switches with 2-3 vlans. we use a isc-dhcp-server running on debian version jessie....
fbcadmin1 by Level 1
  • 451 Views
  • 1 replies
hi,      I would like to know the maximum input voltage that can be applied to a switch sg100d-08 in a safe and reliable way. we plan to use this device in a very harsh environment, therefore it is extremely important to know if 12V is strictly neede...
Hello! ive got 3 cisco sg switches (sg300 20 port managed) i want to make one portbased-vlan with those i simulated the whole thing  in "cisco packet tracer" and it worked, i set the the uplinks of each switch to trunk with vlan "1-1005" ( i once rea...
Hello, we have a SG-300 with latest firmware.  early morning changed from netgear gsm7300 to Cisco sg-300  as our main netowrk switch. I'm having an odd issue. On some vlans dhcp helper does not seem to work.  I probably have something set incorre...
  • 768 Views
  • 6 replies
Has anyone ever had a issue with link drops on this switch?  I read in the data sheets that this switch has an energy mode that monitors ports on active links and puts them to sleep during quite periods.  Could this possible be responsible for interm...
PMCmikemc by Level 1
  • 609 Views
  • 1 replies
Hello Everyone, Yesterday i installed a Cisco SG500-28 als L3 routing switch in our "Core".Today every client with this switch as default gateway gets an "ICMP Flooding Attack" message in our ESET Business Security Firewall.Is there any setting which...
TheUser27 by Level 1
  • 1850 Views
  • 3 replies
I am new to the small business line, but have years of experience on enterprise switching. We have setup a switch as L3 with multiple VLANs, but I have a couple of networks I do not want to be able to telnet, SSH, manage, or ping the switches from. I...
nshoe18 by Level 1
  • 544 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
