SG300 ip routing ??
Harry Chun
hello I'm Harry
I'm korean so I'm not good at speaking in English.
Anyway I have some questions about sg300
I want to ping from valn1 to other vlan's without a router.
As far as I'm concernd, normally switch can use a "ip routeing"commend but I can't use that command on the sg300.
So I can't communicate from vlan to other vlan's.
There are my cofigurations on the sg300 as followings.
ip dhcp pool vlan1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
ip dhcp pool vlan10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.254
ip dhcp pool vlan20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
interface range gi1-3
switchport mode access
switchport access vlan 1
interface range gi4-6
switchport access vlan 10
interface gi7-10
switchport access vlan 20
interface Vlan1
ip address 192.168.1.254 255.255.255.0
interface Vlan10
ip address 192.168.10.254 255.255.255.0
interface Vlan20
ip address 192.168.20.254 255.255.255.0
How could I solve this problem?
Seb Rupik
Hi there,
The command you are probably looking for is:
set system mode router
cheers,
Seb.
o enable routing you need to change the box mode to router (the default is switch mode, ie. L2). The CLI command to achieve this is as follows:
Please be aware of this:
After executing the command, the Startup Configuration file is deleted and the device is rebooted. It is highly recommended to back up the Startup configuration file before executing this command.
