06-03-2013 02:19 AM
What tools are you using to manage multiple SG300 in a single network ?
I can't find any good solutions on the cisco website.
K.
Solved! Go to Solution.
06-03-2013 05:09 AM
Hi Kristof, CCA (Cisco configuration assistant) is the support Cisco tool. If you're familiar with SNMP you may also use this.
-Tom
Please mark answered for helpful posts
06-03-2013 05:09 AM
-Tom
