SG300 Not Forwarding to Default Route
Fork2232
I have an SG300 with fully functional VLAN routing between 4 VLANs that will not forward to the default route.
I am able to ping/traceroute to the default route IP configured on the SG300 of the switch from all VLANs, but when trying to access anything not directly connected to the switch the traffic is not forwarded to the default route.
I have run a tcpdump on the router and no traffic is seen when trying to access anything that should hit the default route.
I have routes for all of the VLANs pointing back to the SG300
All switch ports are configured as Trunk ports as they all go to either other switches or ESX servers that support multiple VLANs.
I also tried setting a static route to something on the other side of the router and that did not work either.  I have seen comments about the ports being configured as access vs trunk, does that make a difference?
I am sure there is some small check-box I am missing somewhere, Any help would be appreciated.
17 Replies 17
Jaderson Pessoa
Well,
could you share your configuration?
what device is used as default route? (router/firewall/isp) do you have access on it? Could you share configuration?
Is there a possibility to provide a simple draw of your topology?
Jaderson Pessoa
*** Rate All Helpful Responses ***
The default route terminates at a firewall running as a VM.  I have full control over it.  As I said, I ran a tcpdump on the internal interface of the firewall and see no traffic forwarded to it from the SG300 when it is a network not directly connected to the SG300.
The firewall has two interfaces, one in VLAN 60 and one in VLAN 30.  Nothing else is located in either VLAN the firewall has full access to the internet.
I don't have a diagram, but it is just a basic network.  I am just moving the routing from the a hardware firewall to the SG300 to give me more flexibility in my lab environment.
Here is the the config:
config-file-header
v1.4.11.2 / R800_NIK_1_4_216_022
CLI v1.0
set system mode router
port jumbo-frame
vlan database
vlan 10,20,30,40,50,60
exit
no ip arp proxy disable
logging buffered debugging
ip ssh server
ip http timeout-policy 0 https-only
interface vlan 10
ip address 10.20.100.253 255.255.255.0
interface vlan 20
ip address 10.22.100.253 255.255.255.0
interface vlan 30
interface vlan 50
ip address 10.19.100.253 255.255.255.0
interface vlan 60
ip address 10.18.100.1 255.255.255.0
interface gigabitethernet1
switchport trunk allowed vlan add 10,20,30,40,50,60
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
switchport trunk allowed vlan add 20
switchport trunk native vlan 10
interface gigabitethernet6
switchport trunk native vlan 40
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
switchport trunk allowed vlan add 20,30,40,50,60
exit
banner login ^C
Switch 2
^C
mac address-table aging-time 30
ip default-gateway 10.18.100.10
if you try to ping 10.18.100.10 from your SG300, works?
Jaderson Pessoa
Yes, everything works that is directly connected.  All of the VLANs can talk to each other.
Good,
on which interface is your "firewall" is connected? this default route is a firewall? Which model? Could you share configuration with us?
Jaderson Pessoa
The firewall is connected through port 7, but it is actually on another switch.  It is Check Point VM and I don't think it is the problem.  If I add a machine to the VLAN it is on I can pass through it, and it has routes, access rules and NAT configured for all of the VLANs.
I am guessing from the questions you don't see anything wrong with the switch config?
@Fork2232
I think that your default route configured is wrong.
try it:
no ip default-gateway 10.18.100.10
ip route 0.0.0.0 0.0.0.0 10.18.100.10
Certify that you will do it on directly network, because maybe you will lose access on your device until it is done.
Jaderson Pessoa
Thanks for the suggestion.  I tried that and it didn't change anything.  If you don't see anything else I may tear it all down and try again, there just seems to be something weird going on.
well... i really want know the result about the command below;
ping 10.18.100.10 source-interface vlan 10
ping 10.18.100.10 source-interface vlan 20
ping 10.18.100.10 source-interface vlan 50
Jaderson Pessoa
All of those pings are successful.
I did some more experimenting and if I stick another device on the VLAN between the switch and the firewall and try to ping 8.8.8.8 through the firewall everything is fine, but at the same time the devices on the other side of the switch can now ping 8.8.8.8...  but only 8.8.8.8.  It is like the switch is still relying on ARP and not following its default route unless it already knows the destination is there.  This is driving me crazy.
Ok, I think that your firewall is the problem.
Disable arp spoofing on your firewall.
Look it: https://community.checkpoint.com/t5/Logging-and-Reporting/Disable-quot-Local-interface-address-spoofing-quot/td-p/14128
Jaderson Pessoa
I have the correct networks configured in anti-spoofing, and it is set to detect, not block.  I am not seeing any of the logs mentioned in the linked article.  Anti-spoofing in Check Point doesn't have anything to do with ARP, it is to detect when improper IP addresses are seen on an interface.
Your switch is configure properly. I had this issue times ago.. and the problem was checkpoint, let me try to explain.
when traffic is comming from one network and match network interface = traffic is allowed.
when traffic is comming from one network and do not match network interface = traffic is blocked by anti-spoofing.
In your case your traffic is send to default route to your firewall then traffic is comming from network that not match network interface the traffic is blocked by anti-spooing, but when you see in the checkpoint's log it is appear as "allowed", but you need see in spoofing logs.
to resolve this issue i had did a few configuration:
Obs: "I dont remember correct path"
advance > security > (search) "spoo" and will apear antispoofing configuration i have disabled it to test... all works well :)
try it... because your switch configuration are ok.
Jaderson Pessoa
I completely understand what you are talking about and spoofing is a commonly misconfigured thing in Check Point.  By default the spoof group will be assigned as the directly connected network, but it is possible to specify a group, and I have created a group with contains all of the internal networks.  It also would not explain why the traffic was allowed through after I connected from a locally attached machine.
That being said, I did completely disable spoofing to verify that wasn't the problem.
I do have this working now, though I don't know the exact cause of the problem, it was not the SG300.  It must have something to do with how VMware Fusion VLANs work.  I moved from Fusion to an ESX box and it immediately started working with no other changes.
