SG300 "Join VLAN" broken
jer0nim0x
Hey,
"Join VLAN" in "Port VLAN Membership" seems completely broken.
First, it does not even show the initially selected port (here I selected GE28 and it shows GE1).
Even when I change it manually in the popup, it does not show any mode or available VLANs to select from (list remains empty/greyed out).
Why could that be? (see screenshot in attachment)
SG300-28 firmware 1.4.7.6
Bye,
Marki
jonrodr2
Hello, my name is Jonathan and I am part of the Small Business Department.
Have you tried different Browsers, it has happened to me on a few cases that the vlans don't show the information to select but we tried other browsers and it was solved, please let us know if the issue persits or if you have tested different browsers.
I've tried FF 45 ESR and IE 11 (Windows 10). With IE it seemingly works after clearing the cache.
However FF ESR is very common in corporate environments and it should work too.
