SG300 - Separating network using vlan?
Brian-SG300
I am wondering what the best way to separate a network, both data, on a cisco SG300. I do not want network 1 to able to communicate with network 2 or vice versa.  I have one server for DHCP for network 1, 192.168.1.X. I would like network 2 to have ip of 10.0.0.X, can the cisco SG300 do dhcp for this vlan?
Thank you for your help,
Brian
Tom Watts
Hello Brian, the SX300 series do not support any DHCP service, you will need a router or a DHCP box for this. The SX300 can separate traffic with VLAN. However, as the default layer 2, all request will go to your router then route to the destinations. As the switch in layer 3 mode, you may have local connectivity, however, if your router does not support the vlans or dot1q encapsulation, the router would require static routes for those subnets to be able to correctly route to the internet.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
