12-07-2014 05:22 AM
Hi Guys
i was hoping someone could give me a pointer on a Vlan setup issue i am having.
Enviroment
Cisco S300-10 Switch (set to L3 Mode)
I have uploaded a newb drawing of my switch config in the hope it may help
From My Office Pc i see the following symptoms
1) I CAN ping Vlan 2's interface (which is 192.168.1.1)
2) I CANT however ping any of the machines inside Vlan 2 (such as 192.168.1.2)
3) I CANT ping Vlan 3's interface (which is 10.0.0.1)
Worth Mentioning as its not on the drawing i did but the office pc has additional ip addresses 192.168.1.200 & 10.0.0.200
From Vlan 2 I see the following symptoms
1) I CAN ping all other Vlan interfaces (such as 10.0.0.1 & 192.168.0.102)
2) I CAN ping all other machines inside Vlan 2
Vlan 2 Machines have the Vlan interface set as their gateway (i.e 192.168.1.1) I have been reading this link to get it as far as i have
https://supportforums.cisco.com/disc...r-vlan-routing
Any help would be greatly appreciated.
Martyn
Solved! Go to Solution.
12-07-2014 08:59 PM
On the router do you have routes back to the networks on the switch?
For Example:
ip 10.0.0.0 sm 255.255.255.0 gw 192.168.0.102
ip 192.168.1.0 sm 255.255.255.0 gw 192.168.0.102
And I'll assume that you have a default route on the switch to the router?
For Example:
ip 0.0.0.0 sm 0.0.0.0 gw 192.168.0.1
12-07-2014 11:27 AM
The first thing that comes to mind when looking at your drawing
is the potential for the this problem, The problems with asynchronous routing
take a look at this, http://networkguy.de/?p=409
If your ping issues that your are seeing are being seen on the office pc
it is most likely because it cannot access 192.168.1.0 or the 10.0.0.0 networks
as from the drawing, those vlans are most likely not trunked between the switch and router
and the router would also have to be vlan aware to do this
and the pc would also have to have nic that do do tagging
as an example of a good setup
take a look at my last post with pictures in this thread
https://supportforums.cisco.com/discussion/12359971/no-internet-sg300-and-rv320
12-07-2014 12:52 PM
Hey phibertron Thanks so much for your reply.
"those vlans are most likely not trunked between the switch and router
and the pc would also have to have nic that do do tagging"
Well that is true, the Router is not Vlan aware (as far as i know anyway, its only a Dlink ADSL router) although the PC NIC has a setting that says "Priority & VLAN Enabled" (not sure what that means.)
so with that in mind please excuse the following questions if they appear silly.
1) If the link between the switch and Office PC isnt trunked why can i ping the Vlan interface of Vlan2 but not Vlan3? shouldnt i be prevented from pinging both of them?
2) On the Vlan config sheet of my Sg300 all my Vlans are set to "trunked" and my ports set to "untagged".....Is this right? Forgive my ignorance (i am a vmware and SAN admin so very rarely delve into networks) but my understanding was that if a Vlan was "trunked" it would only allow tagged Vlan's down that path but if it was set to "access" it would send any traffic down that path?
Thanks again for your help, it has already pointed me in the direction of solving my inability to png between Vlan 2 & Vlan 3 (Vlan 3 had the wrong gateway in it)
Martyn
12-07-2014 08:59 PM
For Example:
For Example:
12-08-2014 04:09 AM
i do have routes on my router to the other subnets
however i had them setup as
10.0.0.0 sn 255.255.255.0 gw 10.0.0.1 (as i thought that gw would be the vlan ip)
192.168.1.0 sn 255.255.255.0 gw 192.168.1.1 (again as i thought the gateway would be the ip of the vlan)
Let me change these and i will let you know the outcomes
***EDIT.... Ok after adding the correct info into the router (i.e the gateway on both routes set to 192.168.0.102) i can now ping the 10.0.0.1 Vlan. i still cant ping past that though into the actual hosts within that Vlan.
i have not specifically set a default route on the switch, i have tried to view what the default route is on the switch but i cant seem to find a command or see a section in the gui.
***EDIT.....Ok after adding the 192.168.0.1 as the gateway for the switch all of my vlans can now get out via my router to the internet (awesome) I can also now ping into Vlan3 (so can ping 192.168.1.2 or 3 etc)
The only thing i cant do now is ping into Vlan2 (my 10.0.0.1 ISCSI) network, but this isnt crucial as its only a storage network and all of the hosts connect to the switch from other Vlans can ping it no problem.
i will set it though and let you know
thanks again
12-08-2014 08:12 AM
Your Welcome, glad to see you made progress
Can you not still ping into the 10.0.0.0 network?
12-08-2014 08:46 AM
Hey Phibertron
No unfortunatly not, not from the office pc but i can from the switch and from inside the 192.168.1.x network
12-08-2014 10:26 AM
"Worth Mentioning as its not on the drawing i did but the office pc has additional ip addresses 192.168.1.200 & 10.0.0.200"
what does the route table on the office pc show?
12-08-2014 01:43 PM
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.3 266
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.0.0 255.255.255.0 On-link 192.168.0.3 266
192.168.0.3 255.255.255.255 On-link 192.168.0.3 266
192.168.0.255 255.255.255.255 On-link 192.168.0.3 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.0.3 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.0.3 266
so i guess it sends it to office pc gateway (192.168.0.1) which then should send it to the static route i have in place.
Thing is i can ping the 10.0.0.1 interface (vlan 2 interface) so the static route on the gateway is working but i just cant get beyond that Vlan 2 interface into the hosts (2 ESX vmk_)
weird
12-08-2014 03:16 PM
can the esx hosts ping your pc?
are the esx hosts gateways correct?
how is the vswitch on the esx hosts setup?
12-09-2014 01:24 AM
Hi Mate
The Esx host can ping the office on Vmk0
~ # vmkping -I vmk0 192.168.0.3
PING 192.168.0.3 (192.168.0.3): 56 data bytes
64 bytes from 192.168.0.3: icmp_seq=0 ttl=128 time=1.737 ms
64 bytes from 192.168.0.3: icmp_seq=1 ttl=128 time=3.200 ms
64 bytes from 192.168.0.3: icmp_seq=2 ttl=128 time=6.276 ms
not from either of the 10.x Vmk interface i cant ping the office pc
~ # vmkping -I vmk1 192.168.0.3
--- 192.168.0.3 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
~ # vmkping -I vmk2 192.168.0.3
~ # esxcfg-route
VMkernel default gateway is 10.0.0.1
Interface Port Group/DVPort IP Family IP Address Netmask Broadcast MAC Address MTU TSO MSS Enabled Type
vmk0 Management Network IPv4 192.168.0.153 255.255.255.0 192.168.0.255 90:e2:ba:0e:cc:20 1500 65535 true STATIC
vmk1 ISCSI 1 10.0.0.x IPv4 10.0.0.2 255.255.255.0 10.0.0.255 00:50:56:60:65:1a 1500 65535 true STATIC
vmk2 ISCSI 2 10.0.0.x IPv4 10.0.0.3 255.255.255.0 10.0.0.255 00:50:56:60:e9:07 1500 65535 true STATIC
Vswitches are just standard vswitches, no vlanning etc.
12-09-2014 11:53 AM
does the esx host have multiple nics?
12-10-2014 01:39 AM
Hi Mate
yes it has multiple.
2 for guest traffic
2 for iscsi traffic
2 for management
