Trying to set up new sg350 10 p - tried using the config file from one used and working but it failed and needed factory reset
my other one has the leds turned off so have no idea what I should see
ports 1 to 8 light green on left light only when using port
9-10 both light when active cable connected.
am I missing something here or shouldn’t both lights be operating when data transfers?
as it’s new just out of box and cant compare to the other working one I’d like to know if this is normal
thanks
