SG350-10P POE Ports fault at startup
RickCutler38212
I have a Cisco SG350-10P Switch.
My POE Devices do not power up after a reboot. I have to go into POE settings and toggle Class / Port settings, then the devices power up.
I have saved the running config file as the startup file and even exported the config file and verified the settings.
Do I have a faulty switch?
marce1000
 - You may want to verify all required settings again using this guide :
   https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb1791-configuration-of-power-over-ethernet-poe-settings-on-cisco-2.html
 M.
I'm using the same settings on other SG300 & SG350 switches I have in my inventory. I just find this issue with 1 particular unit.
All I have to do is toggle the Port/Class setting, then the ports power on.
