Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2912 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4491 Views
  • 1 replies
  • 16 Helpful votes
Hi @All, how do I disable Cisco FindIT on my SG350XG?I dont want to use it at the moment but the connection tries are filling the logs of my other switches. Deleting all device groups did not work as "Default" cant be deleted. Best regards,Hendrik
IFM by Level 1
  • 489 Views
  • 0 replies
Greetings,I have a CISCO SG 300-28 switch, and I was upgrading it's quite old firmware today, first using older major versions of firmwares and boot images and then stpe-by-step using newer major versions.When I've reached the latest firmware version...
JackD-c by Level 1
  • 1170 Views
  • 2 replies
My switch always consumes 100% CPU.I see some-one else had a problem alike, I provided my own debug data in the attachment. I can't find the source. There are 2 switches in stack, the amount of traffic isn't high and the CPU is always consuming 100%,...
tfhelp by Level 1
  • 1670 Views
  • 1 replies
After upgrading my SG200-26 switch to 1.4.11.02, I can no longer access it from Chrome (version 77.0.3865.120). I have cleared the cache, history, etc from my browser. I have rebooted both the switch and the computer I am trying to access it from. Th...
dtheese by Level 1
  • 4547 Views
  • 12 replies
Hello,   I have two SG350X-24 switches I want to stack. I don't have any SFP cables right now. Can I use two RJ45 Cat6a cables instead?    Has anyone used 10gtek 10G SFP+ DAC Cable for Cisco SFP-H10GB-CU0.5M? I saw these on Amazon.  Thanks,Matt
Matt4458 by Level 1
  • 1427 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
