SG350-10P PoE Switch -- Missing Power Cable
chyron8472
My office has an SG350-10P 10-Port Gigabit PoE Managed Switch, but the power cable is missing. I am having difficulty finding a quality replacement cable online, so I need assistance finding one.
Can I purchase a replacement power cable from Cisco?
this power supply is included with switch at original order and i didnot found separate SKU for pwer supply. but i saw some listings in ebay and amazon (buy at your risk and contact sellers to get warranty details). in cisco datasheet i didnot found a ordering SKU.
good luck
rate this and mark as solved if this solved your concern
KB
Good luck
KB
The SG350-10P comes with an external power supply model FSP/FSP090-DMBC1 (AC100-240V,1.5A,50-60Hz). This PS including the power cable is not offered by Cisco as a spare part. You can refer to any third-party seller to find this suitable power cord based on your country. This is how the power supply looks like. Depending on what region the switch operate, the power cord may vary.
