sg350-28p
hashir.shabbir
Running UBOOT...
U-Boot 2013.01 (Aug 16 2021 - 23:32:00) version: 2014_T3.0 V3.5.7.13
NAND ID = 0xDA2C
NAND Model = Micron 2Gb 8bit ABAEA
Loading system/images/active-image ...
Uncompressing Lin done, booting thln: console: File exists
Wed Dec 21 09:29:00 UTC 2016
Linux MARVELL_LINUX 3.4.69 #2 SMP Wed Dec 21 22:02:50 IST 2016
MAC Address : ac:4a:56:f0:90:28.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
*** Running SW Ver. 2.2.8.4 Date Dec 21 2016 Time 22:00:14 ***
HW version is V05
Base Mac address is: ac:4a:56:f0:90:28
Dram size is : 512M bytes
Dram first block size is : 370688K bytes
Dram first PTR is : 0x80000000
Dram second block size is : 4096K bytes
Dram second PTR is : 0x19000000
Flash size is: 256M
21-Dec-2016 09:29:09 %CDB-I-LOADCONFIG: Loading running configuration.
21-Dec-2016 09:29:09 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG350-28P
Device 0: GT_98DX3235 (AlleyCat3)
CPLD version is: 0x03
-- Unit Number 1 --
21-Dec-2016 09:29:29 %INIT-I-InitCompleted: Initialization task is completed
-- Unit Number 1 Master Enabled --
Tapi Version: v1.9.7
Core Version: v1.9.7
21-Dec-2016 09:29:31 %MLDP-I-MASTER: Switching to the Master Mode.
21-Dec-2016 09:29:31 %Environment-W-RPS-STAT-MSG: Power supply source changed to Main Power Supply.
21-Dec-2016 09:29:31 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
21-Dec-2016 09:29:31 %NT_poe-I-PoEPowerSourceChange: Active power source set to PS for unit 1
21-Dec-2016 09:29:32 %HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: HALP_config_poe_number_of_poe_devices is Zero: Failed on init.
***** FATAL ERROR *****
Reporting Task: HCPT.
Software Version: 2.2.8.4 (date Dec 21 2016 time 22:00:14)
ros(HOSTG_fatal_error+0x14) [0x2510a4]
ros(OSSYSG_fatal_error+0x148) [0x7929cc]
ros() [0x5c6ecc]
ros(HALP_config_poe_692xx_dev_op_set_periodic+0xa8c) [0xa776b4]
ros() [0xa6a2fc]
ros(HALP_config_poe_691xx_692xx_poe_dev_operation+0x48) [0xa6a3e0]
ros(HALC_config_poe_dev_operation+0x44) [0xa7b82c]
ros() [0xa1f128]
ros(HALC_config_device_dispatch+0x1a8) [0xa2451c]
ros() [0xa3c244]
ros() [0xa3c450]
ros() [0xa3c4a8]
/lib/libp2linux.so.1(+0x3aa4) [0xb6f1aaa4]
/lib/libpthread.so.0(+0x6e64) [0xb6ef5e64]
***** END OF FATAL ERROR *****
***************** SYSTEM RESET *****************
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
Restarting system.
2 Accepted Solutions
i try but same issue
HW version is V05
Flash size is: 256M
Slot 1 - SG350-28P
-- Unit Number 1 --
21-Dec-2016 09:29:30 %INIT-I-InitCompleted: Initialization task is completed
Restarting system.
5 Replies 5
balaji.bandi
Try to Turn it off completely and test it, if that resolves.
If not Looks for me Bug i guess, Open a TAC Case
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvk62334
BB
HW version is V05
Flash size is: 256M
Slot 1 - SG350-28P
-- Unit Number 1 --
Restarting system.
please guide me
hashir.shabbir
yes i try different firmware but same issue
