SG350 firmware upgrade
Tom.s
Hello everyone,
   I found an SG350-28P in some remote location with quite old firmware 2.4.0.91 and I want to upgrade it to 2.5.0.92. My question is, can I do it in one step? Directly from 2.4.0.91 to 2.5.0.92 or it is better to upgrade to 2.5.0.X first? As the switch is in remote location, I must not brick it. Do you think there will be any issues?
Tom
5 Replies 5
marce1000
 - Check Release Notes for targeted version and look for installation/upgrade guidelines.
  M.
I checked, but there is written nothing about this, I just wanted to ask you as a community if you faced any issues :)
 - For these type of devices direct upgrade/install is usually no problem (but save the configuration first).
  M.
You were right, I went directly for the latest version and there was no issue.
Thank you :)
aturawat
Hi Tom,
I can see that you have put this question regarding the firmware upgrade.
I would suggest you to upgrade the firmware version one by one on all switches.
Here is the link given below to upgrade the firmware:
https://www.cisco.com/c/en/us/support/switches/sg350-28p-28-port-gigabit-poe-managed-switch/model.html#~tab-downloads
Atul
CISCO TAC
