Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2635 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7265 Views
  • 4 replies
  • 17 Helpful votes
I managed to bork a SG350-10P and running Release 2.5.5.47.  It was fine running Release 2.5.0.92 and when I upgraded it to 2.5.5.47, it went into a reboot loop.  I consoled into the switch to tell it load 2.5.0.92, but was unsuccessful.  I also relo...
I am new to networking.I need to create 2 vlan ,with all vlans able to access internet using ISP router( The ISP router cannot create trunk port/vlan only direction connection.) DEFAULT VLAN 1-192.168.3.1/24--->G1VLAN 10-192.168.10.1/24--------->G2VL...
How do I get an ACL on an sg500 to deny all traffic from my 192.168.1.0/24 subnet to my CCTV subnet 192.168.20.0/24 apart from 1 host IP  192.168.1.8 Use to catalyst switches in which ACLs seemed more logical
Dav1787 by Level 1
  • 1600 Views
  • 5 replies
Dear all, My customer uses 7 x SG550x-48P and connect full to 250 Camera. All SG550x is stacking and from Access switch will have 2 link 10GB to connect to 2 Core Switch. All camera is Avigilon with image Full HD. Now, the problem is with 250 camera,...
khang2711 by Level 1
  • 806 Views
  • 0 replies
Hi, I wonder if it's normal for the PoE voltage be very fluctuating?I have seen voltages from as low as 31V all the way up to 94VMainly I monitor the switch via SNMP using Observium, but I have also observed strange voltags using CLI command:  show p...
gberg by Level 1
  • 2949 Views
  • 13 replies
Hi, i have two SG550x Switches as a Stack. I need a Layer2 redundancy between my Stack and two switches on the other Side. The Other Side are Switches that dosen't support LACP, LAG or Spanning Tree. I think Flex Link will solve my Problem but i can'...
Omega666 by Level 1
  • 442 Views
  • 0 replies
Hi, I just want to know where to download the latest firmware and boot images for SG300 on v04 hardware version.  The release notes of fw1.4.8.6 available at the product support site made no mention on hardware version other than v01 and v02 - see sn...
Jet by Level 1
  • 3703 Views
  • 6 replies
Apologies for the long title. This firmware update *just* came out. Usually I wouldn't brave it this soon. But my circumstances are this: I have used gear arriving that I've acquired for a lab setup for a couple of related projects and I have qty 2, ...
Zed969 by Spotlight
  • 2037 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
