SG350X-48P FW: 2.4.5.71 %MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 17 service Snmp
henrihoffmann
I receive a lot of this kind of messages after the last FW upgrade.
There is a mgmt acl in place, so this is okay, but what is "interface User Defined Port 1"  and who is 169.254.0.2?
Henri
mipopov
Hello Henry,
169.254.0.2 is the second APIPA address
APIPA stands for 'Automatic Private IP Addressing'
https://learningnetwork.cisco.com/thread/66533
As for the packet is not enough information.
Hope it helps
Cheers,
Mike
Hi Mike,
thanks a lot for your reply.
1.) I get this message on 2*SG550XG (stack1) und 2*SG350X(G) (stack2) AFTER a FW upgrade
2.) Which interface is "interface User Defined Port 1" ? It would be helpful to know where to look.
3.) SG550XG stack:
switch4#ping 169.254.0.2
Pinging 169.254.0.2 with 18 bytes of data:
PING: no reply from 169.254.0.2
PING: timeout
PING: timeout
PING: timeout
PING: timeout
----169.254.0.2 PING Statistics----
4 packets transmitted, 0 packets received, 100% packet loss
switch4#ping 169.254.0.1
Pinging 169.254.0.1 with 18 bytes of data:
18 bytes from 169.254.0.1: icmp_seq=1. time=0 ms
18 bytes from 169.254.0.1: icmp_seq=2. time=10 ms
18 bytes from 169.254.0.1: icmp_seq=3. time=0 ms
18 bytes from 169.254.0.1: icmp_seq=4. time=0 ms
----169.254.0.1 PING Statistics----
4 packets transmitted, 4 packets received, 0% packet loss
round-trip (ms) min/avg/max = 0/2/10
sh arp ip 169.254.0.1
VLAN Interface IP address HW address status
switch4#sh arp ip 169.254.0.2
4.) There are of lot of messages ...
15-Jan-2019 23:41:01 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 17 service Snmp
15-Jan-2019 23:41:00 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:41:00 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Https
15-Jan-2019 23:40:24 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:40:21 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 17 service Snmp
15-Jan-2019 23:39:56 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:39:54 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:39:53 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:39:52 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 17 service Snmp
15-Jan-2019 23:39:51 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 17 service Snmp
15-Jan-2019 23:39:51 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:39:27 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
15-Jan-2019 23:39:23 :%MNGINF-W-ACL: Management ACL drop packet received on interface User Defined Port 1 from 169.254.0.2 to 169.254.0.1 protocol 6 service Http
Henri
