SG350X+SG350XG Stack FW: 2.4.5.71 Alert %Environment-A-FAN-STAT-CHNG: FAN# 1 status changed to not operational.
henrihoffmann
received this message with last FW.
Is there a fan fault and if this true on which stack device?
Henri
mipopov
Hello Henry,
What is the output from commands :
switchxxxxxx# show system fans
switchxxxxxx# show system sensors
 Cheers,
Mike
Hi Mike,
thanks for your reply.
As requested:
Core#show system fans
Unit ID: 1
Expected Fan(s) RPM: 8892
Unit/Fan ID Fan Status
1/1 OK
1/2 OK
1/3 OK
Unit ID: 2
Expected Fan(s) RPM: 4251
2/1 OK
2/2 OK
2/3 OK
Core#show system sensors
Unit/Sensor Sensor Status Temperature (C) Warning Alarm Temp(C) Critical Alarm Temp(C) Location
1/1 OK 33 55 59 PCB
1/2 OK 45 67 71 PCB
1/3 OK 53 88 91 PP
1/4 OK 52 87 90 PP
1/5 OK 46 94 98 PoE
2/1 OK 45 76 82 PCB
2/2 OK 46 78 83 PCB
2/3 OK 43 75 80 PCB
2/4 OK 44 73 77 PCB
2/5 OK 74 101 105 PP
Henri
Hi again,
Looks good :) - all fans running and temperature is good
sure, but I received this message multiple times in the past (>100).
Henri
