SG350XG-2F10 stack sudden reboot
Hi. I've got hybrid stack of 4 switches
1 SG350XG-2F10
2 SG350XG-2F10
3 SG350X-48
4 SG350X-48
Sometimes (approx. once a month)  master unit goes to reboot, then backup unit becomes a master and reboots too. Slaves don't reboot. All units are powered from UPSs (master and backup from different one). Enviroment is OK (+19C air conditioned room). Software Version: 2.5.0.79
sh log file shows this:
Reporting Task: BRGS.
Software Version: 2.5.0.79 (date Apr 20 2019 time 23:59:08)
base_address=0xb46db000
ros(+0x78a558)[0xb4e65558]
ros(HOSTG_fatal_error+0x10)[0xb4e67b5c]
ros(OSSYSG_fatal_error+0x2a0)[0xb5431544]
ros(+0xb582b0)[0xb52332b0]
ros(PSETG_add_port_to_set+0x50)[0xb5382b8c]
ros(SW2G_tx_to_vlan_subset+0xac)[0xb56fccf4]
ros(NETG_l2_bridge_forward+0x4e0)[0xb560c664]
ros(+0xbbe608)[0xb5299608]
ros(NETG_l2_snoop_app_gcall+0xa4)[0xb562e8f0]
ros(+0xc86b70)[0xb5361b70]
/lib/libp2linux.s
At previous reboot it's like this:***** FATAL ERROR *****
base_address=0xb46b4000
ros(+0x78a558)[0xb4e3e558]
ros(HOSTG_fatal_error+0x10)[0xb4e40b5c]
ros(OSSYSG_fatal_error+0x2a0)[0xb540a544]
ros(+0xb582b0)[0xb520c2b0]
ros(PSETG_add_port_to_set+0x50)[0xb535bb8c]
ros(SW2G_tx_to_vlan_subset+0xac)[0xb56d5cf4]
ros(NETG_l2_bridge_forward+0x4e0)[0xb55e5664]
ros(+0xbbe608)[0xb5272608]
ros(NETG_l2_snoop_app_gcall+0xa4)[0xb56078f0]
ros(+0xc86b70)[0xb533ab70]
/lib/libp2linux.so.1(task_run+0xf4)[0xb4644818]
With software 2.4.5.71 it was like this:
Reporting Task: BRMN.
Software Version: 2.4.5.71 (date Nov 4 2018 time 19:41:09)
ros[0x2e6070]
ros(HOSTG_fatal_error+0x8)[0x2e84d8]
ros(OSSYSG_fatal_error+0x270)[0x887714]
ros[0x69f9e0]
ros[0x8a0d2c]
ros[0x90a36c]
ros[0x9156ec]
ros[0x919bc4]
ros[0x91ec14]
ros[0x7bf118]
/lib/libp2linux.so.1(task_run+0xf4)[0xb6f3d818]
sh run at attachment (before last reboot, today i disabled lldp, udld, http and https server).
riteshsh
Please disable smartport and configure VOICE VLAN manually.
Data VLAN and Voice VLAN should not be the same.
If still facing an issue, please open a new case with us by calling frontline support team, so that we can troubleshoot the issue further :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Please mark this as helpful if it resolves your query.
Ritesh Sharma
Thanks, riteshsh!
I've changed Voice vlan id and disabled it. Also disabled smartport on each interface.
Switch#show voice vlan
Administrate Voice VLAN state is disabled
Operational Voice VLAN state is disabled
Best Local Voice VLAN-ID is 666
Best Local VPT is 5 (default)
Best Local DSCP is 46 (default)
The Operational Voice VLAN-ID is 666
Aging timeout: 1440 minutes
CoS: 6
Remark: No
Switch#show macro auto ports
SmartPort is Enabled
Administrative Globally Auto SmartPort is disabled
Operational Globally Auto SmartPort is disabled
Interface Auto SmartPort Persistent SmartPort Type
Admin State State
te1/0/1 disabled disabled default
te1/0/2 disabled disabled default
te1/0/3 disabled disabled default
However, it says Smartport is Enabled. Can't find how to disable it.
UNfortunately, disabling smart port didn't help. I've also upgraded software.
17-Jul-2019 15:19:59 :%STCK SYSL-A-UNITMSG: UNIT ID 2,Msg:%PSET-F-ILLEGAL_IFINDEX : PSETG_add_port_to_set: Illegal ifIndex 0
Reporting Task: NCDP.
Software Version: 2.5.0.83 (date Jun 18 2019 time 16:44:23)
base_address=0xb46ee000
ros(+0x78a5f0)[0xb4e785f0]
ros(HOSTG_fatal_error+0x10)[0xb4e7abf4]
ros(OSSYSG_fatal_error+0x2a0)[0xb54445dc]
ros(+0xb58348)[0xb5246348]
ros(PSETG_add_port_to_set+0x50)[0xb5395c24]
ros(SW2G_tx_to_vlan_subset+0xac)[0xb570fd34]
ros(NETG_l2_bridge_forward+0x4e0)[0xb561f6a4]
ros(+0xdcccdc)[0xb54bacdc]
ros(+0xdceb6c)[0xb54bcb6c]
/lib/libp2linux.so.1(task_run+0xf4)[0xb467e818]
Case 687119919
