Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2969 Views
  • 1 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7514 Views
  • 4 replies
  • 17 Helpful votes
Hello,I've been monitoring the switch, there is something I do not understand.1.3.6.1.2.1.17.7.1.2.2.1.2.1.0.176.220.73.183.218 = Int32: 0 The bold is Vlan.The underlined is MAC. But the value is the port it is assigned to, and it's 0.How come it is ...
BenGordon by Community Member
  • 684 Views
  • 1 replies
As the title suggests : Where to find a working Comms/ Serial 'Cisco Compatible' cable and adapter for Windows 10 1903 I have tried three different cables , for two different Cisco Switches ( SG220 , SG300) Two with USB to RJ45 serial  and one USB to...
90Ninety by Frequent Visitor
  • 552 Views
  • 0 replies
Dear All. Good day. i'm a beginner for Cisco Switches configuration, usually i'm doing a simple configuration for a small business use. now i have a Cisco Switches (SF350-24P), and i stucked with this Auto voice vlan thing. i tried my best to make th...
Hello,I spoke with Cisco about this, they indicated there is no such command for the SG series, but I found he had to look up much of what I asked him (So I am just double checking with other Cisco gurus out there before I let this go.  Does anyone k...
Hello, I have this error message on my c4507R: "The DHCP database could not be locked. Please retry the command later" Since I found out the all commands of dhcp disappeared from running-configuration, so I just wrote them again and it started work...
muchan0124 by Community Member
  • 11991 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
