02-14-2018 10:12 AM - edited 03-21-2019 11:21 AM
I am about to stack a SG500-28 switch to an existing SG500-28. Both are in native stack mode. Will it reboot the exisiting SG500-28 that is in production? Do I need to plan for downtime for this?
Solved! Go to Solution.
02-19-2018 03:34 AM
Hello SuperIT,
Yes. It will reboot and may even try to synchronize firmware between those two if different. It is the must to allocate some downtime for this. Make a not also that some configuration need to be erased for example ports ID will change once stacked... Better to allocate some time to verify that everything works es expected.
Aleksandra
02-19-2018 03:34 AM
Hello SuperIT,
Aleksandra
02-20-2018 09:57 AM
Thanks.
