08-08-2012 06:49 AM
Apply the following commands to Cisco Switch command line:
Roger
Solved! Go to Solution.
08-08-2012 11:32 AM
Hello Roger, try the following;
config t
int gi1/1
no macro auto smartport <- disable smart port for detecting link
switchport mode general <- sets port to 802.1 q
switchport general ingress-filter disable <- removes filtering of vlan tag for the ingress
switchport general allowed vlan add 100,200 tagged (or untagged, however you need it) <- allowed the vlan on the port
spanning-tree portfast <- enables port fast
-Tom
08-08-2012 11:32 AM
config t
int gi1/1
-Tom
03-30-2014 11:59 AM
On my switch it does not have the "switchport mode general" or "switchport trunk encapsulation dot1q" - I get an error (you know, the ol' invalid command or syntax with the little marker). The switches are catalyst WS-C2960-24TC-L with the Cisco LAN Base software. They are less than 3 years old. I hope this means that the encapsulation is set to 802.1Q by default. Does anyone know for sure, or how I can tell? Many thanks!
Sam
